AlanM Posted February 23, 2022 Report Share Posted February 23, 2022 I have a Ryobi One+ R18CS circular saw (standard blade - 165mm, thin kerf, 16mm bore, 24 tooth blade) I am intending to cut quite a lot of melamine faced board (wardrobe doors and drawer faces). I have been told that for a good finish I need to get a 60-72 tooth cross cut blade. Ryobi do not seem to do one. Can you advise me who's blade is best and would fit? [There seem to be many blade suppliers, but I am assuming many will be poor quality/short life, but do not know which are not!]. Thank for any advice. Quote Link to comment Share on other sites More sharing options...
wingless Posted February 23, 2022 Report Share Posted February 23, 2022 Welcome to the forum. For both my 7¼" circular saw and my 10" table saw I have a Freud Ultimate Plywood and Melamine blade, LU79R007 for the 7¼" and LU80R010 for the 10". For your Ryobi 165mm blade diameter w/ a 16mm arbor, unfortunately the Freud Ultimate Plywood and Melamine blades LU79R006M20 or the LU96R006M20, both 160mm diameter but w/ a 20mm arbor won't work. All these are rated by the manufacturer as excellent for melamine. A correct application carbide blade will have the best results / life. Quote Link to comment Share on other sites More sharing options...
wingless Posted February 24, 2022 Report Share Posted February 24, 2022 Is usage of a different cutting tool (different circular saw or a table saw) an option, to permit usage of one of these Freud Ultimate Plywood and Melamine blades? Quote Link to comment Share on other sites More sharing options...
