Intreasting question
Drewster2012
Hi all, first post here not really sure where it goes. i have a Bosch power-box 360 and i want to use it when i go ice fishing this weekend. i thought i read that if it gets to cold it shuts off till its the right temperature again. if this is true is there a way to bypass is so i can use it when im ice fishing in the 10 degree or less weather? thanks!
I've got the 360 too. No probs with mine either! Have fun!
thanks. cant wait to take it out then!
You should be fine using your Power Box!  I take it out of my trunk when it's in the negative temps here, and it fires right up.  I thought it goes down to -4 is what I thought.  I don't think you should have a problem.
i thought one time i took it out and it shutoff  becuase of that.. mabey i am wrong.. but sweet then.. ive got like 4 batterys to use so at full blast i should be good!
    JohnB
    JohnB
