Ryobi 54" zero turn deck buildup
One of the things I absolutely hate about this mower is how badly and quickly grass accumulates under the deck. First thing out of the box I undercoated the entire underside with what was supposed to be a premium graphite undercoat which was supposed to eliminate this problem.  The finish seemed quite slippery and I really expected it to work. But alas, it doesn't seem to even minimize the buildup. I don't cut wet grass though even dry grass contains a lot of moisture. I'm not using mulching blades either. I tried the mulching kit but that was impossible. Any thoughts on a product that might work better? I'm getting tired of getting under there almost every time I mow to clean it.
    Ren
    Ren
