Tye8503 Posted May 29, 2011 Report Share Posted May 29, 2011 Hello, I'm hoping someone can help me with my issue. I recently purchased a DeWalt 18v Lithium Ion drill from an online store, and am having some issues getting the batteries to take a charge. When I put a drained battery in the charger, I get the double flashing light, which my manual says means that I'm using an invalid power source. Has anyone had this issue before? I'm just plugging it into a standard wall outlet. I've gotten it to charge sometimes, but not others. Sometimes if I unplug it for a short time, then plug it back in, it will charge. Other times it gets halfway through a charging session and starts double flashing again. I'm at a loss for what could be causing this. Any ideas? Thanks! Quote Link to comment Share on other sites More sharing options...
kjones Posted May 30, 2011 Report Share Posted May 30, 2011 Because you ordered it off line, I would recommend bypassing the "return and exchange" method, and go strait to your local service center. If it was a new tool, it will be under warranty (even if it is out of date code, show your receipt). Quote Link to comment Share on other sites More sharing options...
