jlhdiver Posted June 3, 2011 Report Share Posted June 3, 2011 My DW 423 Orbital Sander seems to have lost power, I can stop the pad with my hand easily.....is this a motor issue or is there a clutch mechanism that needs replacing??? Quote Link to comment Share on other sites More sharing options...
kanxrus Posted June 3, 2011 Report Share Posted June 3, 2011 You may have had a retainer, or a bearing wear out? Have you taken it apart? Quote Link to comment Share on other sites More sharing options...
jlhdiver Posted June 14, 2011 Author Report Share Posted June 14, 2011 Yea, I took it apart and checked the bearing, it didn't have any play in it. I also looked at the brushes and they looked good.... Is it possible that only one of the brushes is working and that leads to less power, or would it not start up at all? Thanks Quote Link to comment Share on other sites More sharing options...
randomuser123321 Posted December 9, 2011 Report Share Posted December 9, 2011 Bit of an old post, but I had a similar issue with their orbital sander, model D26453. List of symptoms in order of appearance - Not starting; would have to flip the switch a few times - Slow starting; would take a few second to ramp up to normal speed - Not starting unless machine was shaken - Loss of power while using; would improve if pressure applied to motor housing - Finally it was 'dead' This all happened in the span of 2 weeks. I pulled the brushes, they were not excessively worn but one brush had a significant layer of carbon. The armature where the brushes contact was also covered in a layer of carbon. A bit of rubbing alcohol and superfine steel wool removed the carbon on the brushes and armature and the sander is now working fine. I have used the sander less than 1 year so I was a bit surprised that it was so gunked up, but I have been using 320 grit paper for some projects and the inside of the sander was covered in superfine dust; I am thinking that may have been a significant contributing factor. Quote Link to comment Share on other sites More sharing options...
Russ1393434539 Posted December 10, 2011 Report Share Posted December 10, 2011 So orbital sanders can get clogged up. I've only used a orbital sander several times before and I noticed with the orbital sander I was using (it was a friend's) it had a real issue of containing the occasional bit of dust, but it was fixed with some masking tape. Mind you, from what I gathered, this sander is more than a decade, if not older, old. I don't know the model number, but it was made by Dewalt. To be honest, I didn't know these sanders had brushes either, but remember, it wasn't mine, so it's not like I could take it apart and see. I wonder though, this may be slightly off topic and may be more of a question than anything, but does Dewalt even cordless orbital sanders? Or does something like that not even exist? I imagine there must be as if there are cordless drills, there must be cordless sanders. If anyone has any information, boy would that be cool to hear. Quote Link to comment Share on other sites More sharing options...
