mixedgasdiver Posted January 19, 2012 Report Share Posted January 19, 2012 Greetings, I just picked up a 12v Max kit and am curious about the torque settings on the DCS6102 1/4" screwdriver. Does anyone know of a chart so I could then relate the numbers on the dial on the front, to inch pounds or foot pounds of torque? Thanks for the info. Quote Link to comment Share on other sites More sharing options...
kanxrus Posted January 19, 2012 Report Share Posted January 19, 2012 I am not aware of any such chart? I'm not sure it would do you any good. There are way to many variables to consider when driving a fastener, for a torque setting to have any value. Size of the fastener, type of material the fastener is going in, the accuracy of the clutch itself, the speed at which you drive the fastener, etc.... What are you doing that you would need these numbers? Quote Link to comment Share on other sites More sharing options...
mixedgasdiver Posted January 19, 2012 Author Report Share Posted January 19, 2012 Hmmm... I see what you're saying about the type of fastener, material, etc. I was hoping that the clutch would be accurate enough to have some numbers associated with it. I do a lot of work on motorcycles, it's not a full time gig, but I at least make play and vacation money this way. All the fasteners on bikes (just like cars) have a torque spec. Traditionally I use a torque wrench and a torque screwdriver with bits that I can change out. For bigger jobs I'll use my air tools, but most jobs are not this big and I don't like listening to the compressor or fighting with the hose for small jobs. After finding out how great and easy to use these tools were, I thought I could use the driver for reassembly of parts. I'll keep hunting and let everyone know if I find something. I have emailed DeWalt, but not gotten anything back yet. Quote Link to comment Share on other sites More sharing options...
tooljoe Posted January 20, 2012 Report Share Posted January 20, 2012 Traditionally I use a torque wrench and a torque screwdriver with bits that I can change out. here an idea, how about using the torque wrench on a bolt first then use the drill settings to sort of calibrate... I do that on things... I tighten up a screw by hand then set my drill to the lowest number and go up until it stops clicking... that works for me. edit: brain fog. Quote Link to comment Share on other sites More sharing options...
quig1984 Posted January 20, 2012 Report Share Posted January 20, 2012 if you got the kit you prob got the impact driver to I'm guessing? Its will deliver 79ftlbs. I'm guessing read that given that ur asking about the screwdriver Quote Link to comment Share on other sites More sharing options...
