Best mitre saw
Matc88
Specs on the Makita says it cuts 75mm x 130mm max... although you will probably get a bit more cross cut on thinner material...
I roll with the DWS780 XPS.. 305mm blade, and 110 x 305 cut... although I can get about 325 cross cut (@90 degrees)..
The XPS light (cross cut positioning light) works real well, and especially in the Winter, where it actually makes the saw safer to use as it almost acts like an area work light..
If it is slightly too big for you, try the DWS 717 XPS... same style of saw but with a 10" blade rather than the 12"...
    Ryan1049
    Ryan1049
