71Challenger318 Posted February 28, 2013 Report Share Posted February 28, 2013 I recently purchased an older used DW059 (has base for ni-cad I'm using xrp lithium). Worked OK then was down on power. Took it apart and found it needed a brush and the fan shroud was broken. Replaced those two parts, seems to work. My last impact was a 20v Craftsman Pro and it was badass. This thing is pretty sad. It has trouble with car lug nuts. Is this just how they are or is mine messed up? Any way to test it? Quote Link to comment Share on other sites More sharing options...
kjones Posted February 28, 2013 Report Share Posted February 28, 2013 If the brushes were worn out, you probably have a worn out motor as well. I would recommend getting a GRC service. It should have plenty of power when running healthy. Quote Link to comment Share on other sites More sharing options...
71Challenger318 Posted March 1, 2013 Author Report Share Posted March 1, 2013 If the brushes were worn out, you probably have a worn out motor as well. I would recommend getting a GRC service. It should have plenty of power when running healthy. The wire in the one brush was loose. I tried to solder it in but just made it worse. The actual brush surface looked good. So I don't think it is to worn out. How could I go about testing it? Quote Link to comment Share on other sites More sharing options...
sandrafedrer Posted March 20, 2013 Report Share Posted March 20, 2013 May be the piece which has been purchased is not of good quality . So the defects are arising. Quote Link to comment Share on other sites More sharing options...
