saturn Posted May 21, 2013 Report Share Posted May 21, 2013 I just bought this DC822 used yesterday for $50 from a guy who sells tools normally at local events. I would prefer brand new, but I'm a college student. I need it in regards to cutting down the time I am working on my car so I can focus on other things. I was told that it had not been used much.... and that the guy upgraded to the 20V system (thus why could sell this), the casing looks decently clean (few scuffs) nothing big though.... When I power it on, not using it, it is able to rotate the 1/2 drive to 3/8 drive 4' extension that I have bought But as soon as I put a 15mm socket to remove the blades from my fathers lawn tractor..... I hear the motor running but nothing is visible on the drive I break the bolt with my breaker bar & then try it again.... with the bolt loose..... same thing I hear the motor running but nothing is visible on the drive. I left the impact sit for 30 minutes and the I go ahead and grab the extension with my hand and hold it.... but this time I hear absolutely nothing & believe that my battery is going dead..... A bit on the battery I bought it last year with my DC970 has been charged about 30 times max & I did use it yesterday for about a hour in my DC970 to remove about 40 screws. What could of caused the bolt not turning (even when loose) while I was using my DC822? I'm hoping that it's not the drill & that I wasted $50 bucks...... If it is the drill what can be done about it? Thank you for time...... Quote Link to comment Share on other sites More sharing options...
Gatorb8881393434512 Posted May 21, 2013 Report Share Posted May 21, 2013 Sounds like the drill is broken, you can take it to an authorized or factory service center and have it repaired. If the drive isn't spinning but the motor is, it's definitely broken, it's not supposed to do that. Sorry for the disappointment. Quote Link to comment Share on other sites More sharing options...
saturn Posted May 21, 2013 Author Report Share Posted May 21, 2013 Okay Battery Charged.... removes bolt no problem..... What is upkeep on this impact (I want it to last SUPER long)? Suggestions on what to do/ not to do? Any other help? Thanks Quote Link to comment Share on other sites More sharing options...
Gatorb8881393434512 Posted May 21, 2013 Report Share Posted May 21, 2013 No upkeep required, just keep in dry. Quote Link to comment Share on other sites More sharing options...
