forester Posted December 16, 2013 Report Share Posted December 16, 2013 boards not feeding through the planner properly. Sometimes I have to push through with another board. What am I doing wrong?? Quote Link to comment Share on other sites More sharing options...
Gatorb8881393434512 Posted December 16, 2013 Report Share Posted December 16, 2013 How old are the blades? need new ones? Quote Link to comment Share on other sites More sharing options...
Grumpy MSG Posted December 18, 2013 Report Share Posted December 18, 2013 You a few potential causes. The first would be the shape of the actual boards you are running through the planer. If they don't have a somewhat consistent thickness they will have trouble being drawn through the by the feed rollers. The other potential problem would be damaged or dirty feed rollers. I have run a bunch of oak fence boards through mine and at times they are a little thin and need push. You do need to take a good look at the boards before running them to make sure that you se the depth based on the thick parts of the board, not the thin. The worst board I have run had almost 1/4 inch of difference between the thick part if the board and the thin, which happened to be on one end. Quote Link to comment Share on other sites More sharing options...
