Guest Dan Posted June 6, 2014 Report Share Posted June 6, 2014 I'm looking of something I can plug a tool battery into that will supply power that I need to run an actuator. Want something that the battery plugs (i.e. Dewalt battery) into then has a wire coming from it that I can hook up to the actuator. It pretty much is going to look like a tool battery charger but needs to work in reverse. Anyone know where I can get something like that? Quote Link to comment Share on other sites More sharing options...
Conductor562 Posted June 6, 2014 Report Share Posted June 6, 2014 Make one? Quote Link to comment Share on other sites More sharing options...
DR99 Posted June 6, 2014 Report Share Posted June 6, 2014 If you ever watch Mythbusters they use cordless batteries all the time to more actuators, but they tend to just hold the wire on positive and negative terminals on the battery pack. There isn't any sort of prebuilt solution you could probably hack or modify one of the power adapters from a heated jacked to do what you want to do. Just a warning that me or TIA is not responsible for any injury or damage to your property if you act on this information. Quote Link to comment Share on other sites More sharing options...
