ford1386 Posted February 19, 2015 Report Share Posted February 19, 2015 My chuck in my dcd970 messed up today when I try to back a screw out with it the chuck loosens up and the bit falls out with the drill in reverse. So I am figuring the chuck is bad (rohm supra sk), and now they make a conversion kit, so dewalt must have had problems I'm assuming. My question is how do I remove the rohm supra sk chuck? I loosened the chuck all the way and put a pair of channelock pliers and turned the chuck counterclockwise and it feels like I'm gonna snap the drill in half if I put any more pressure on it. Am I doing something wrong? Thanks Andy Quote Link to comment Share on other sites More sharing options...
framer Posted February 20, 2015 Report Share Posted February 20, 2015 did you look down inside the chuck? usually there is a screw threaded into the end of the shaft(through the chuck). i think its reverese thread. Quote Link to comment Share on other sites More sharing options...
Charlie Posted February 20, 2015 Report Share Posted February 20, 2015 What type number is it? That will be next to the model number on the drill...The type 1 is the one using the conversion kit because to replace the chuck, you literally have to replace the entire transmission. The kit turns the type 1 into a type 2... On the type 2 and 3, as framer said above, there is a screw inside that is a torx 20 LH thread.... Pull that screw, then the chuck should unscew in the right direction... Quote Link to comment Share on other sites More sharing options...
