Dewalt D25940 Demo hammer Problem
Fossil22
Sounds like it could be the switch. Just make sure when your messing with the switch as you stated above, your not moving the tool. Try placing it on the work bench and if the get the same result, then it is the switch. If you place it on the work bench and only the switch moves, but nothing happens then you might have a problem with a connection inside that might be corroded
    patric333
    patric333
