Very smart..!!!
Kenneth Denmark
OK so let me get this straight. So you drill two different type of screws into each end, then you put the ends together, and use a drill magnet attachment to cause the screws your drilled in earlyer to tighten. If I understood that correctly, then yes I agree, screwing is the future. The idea here is that you can now put things together using what appears to be invisible screws, I assume if you wanted to remove them, you would just run the drill in reverse, correct? I guess we will see if this idea really takes on, keep in mind it has to past factory tests before factories convert to using this method on the assembly line.
True!
    glen608
    glen608
