KnarlyCarl Posted January 10, 2016 Report Posted January 10, 2016 Five years ago, I installed in my house a new Navien 240 LP tankless water heater with the built in circulator. No regrets whatsoever. What I and others didn't realize at the time, was how bad the water going through it was. It's bad water everywhere in this area and we've since put together an aggressive service agenda to alleviate problems associated with water quality and our customers' water heaters. But back to the story at hand, I realized I never flushed my water heater; tankless water heaters should be flushed every year or two with cleaning vinegar. It's a simple task since the valves installed on them allow it to be isolated and garden hose connection for pumping vinegar through. I had never flushed mine out so I thought I better pump some vinegar through, then let it sit for the majority of the day, then flush it out with clean water. What else would I have expected than this I guess I shouldn't be surprised:The following is a humorous text between myself and a coworker who is known for taking a dump in buckets when he gets desperate; [emoji1] Sent from my SCH-I535 using Tapatalk 2
John Glassey Posted January 10, 2016 Report Posted January 10, 2016 Wow does that go for all tankless heaters. I do my Keurig every 6 months and never looked like that lol. Sent from my iPhone using Tapatalk
KnarlyCarl Posted January 10, 2016 Author Report Posted January 10, 2016 Good call on that yes for sure, there is always gonna be build up with heating water unless it's completely devoid of minerals and other substances, like distilled water. Sent from my SCH-I535 using Tapatalk
John Glassey Posted January 10, 2016 Report Posted January 10, 2016 Thanks for posting that. I've been wanting to switch to a tankless heater and now know that there will be an additional maintenance step is helpful information. Thank you for that, not that it will change my mind on it. Just good info.
JimboS1ice Posted January 10, 2016 Report Posted January 10, 2016 If that's his poop bucket he's got some issues...Nice post though mineral buildup is no joke, have had issues in our area from extremely hard water.JimboSent from my iPad using Tapatalk
99_XC600 Posted January 10, 2016 Report Posted January 10, 2016 This reminds me that I need to flush my Takagi tankless. Best thing I ever did was purchasing this for my house. I love it.
John Glassey Posted January 10, 2016 Report Posted January 10, 2016 Yes PROTOOLNUT! Your statement is just what I was thinking. I would love to go tankless. Sent from my iPhone using Tapatalk
KnarlyCarl Posted January 10, 2016 Author Report Posted January 10, 2016 Switching from electric tank water heater to gas tankless requires venting for intake and exhaust (2" pvc sch. 40) a gas supply, and 120v instead of 240v, plus it's wall mounted. It's frees up a lot of room, you can mount it up higher if you like to access the underside of it, which is where you will flush it out at. Get tankless valve/unions for it so it can be isolated when it needs to be serviced. Mine has a 12 year heat exchanger warranty and 3 year parts I think. I think flushing is super easy, I have a small utility pump, three washing machine hoses, a bucket, and 2 gallons of cleaning vinegar. Why I didnt do it sooner, well, no excuses I guess.https://files.acrobat.com/a/preview/2496c73f-3226-4720-a434-474812158c39Sent from my SCH-I535 using Tapatalk
99_XC600 Posted January 11, 2016 Report Posted January 11, 2016 You have 2 options. You can go with an electric version of get a propane one and then just get a bottle placed somewhere on your property and set it up.
DR99 Posted January 11, 2016 Report Posted January 11, 2016 You should flush any hot water tank out, but I believe 99% of the population never does it. The big thing with tanked water heaters is if you want a longer life is to replace the sacrificial anode it keeps to tank from corroding. That is another thing people never do. The one thing Protool is if you go Electrical Tankless is you need to run some serious amperage from the panel to the unit. I don't know if electric tank less units are worth it with the increased power draw and the cost of installation. The one thing is new water heaters are bigger because they added more insulation to make them more energy efficient, so some water heaters won't fit in their old locations. You either have to find a new old stock water heater or a lightly used one if you want a direct replacement. They also make ones that fit, but they don't have as much tank capacity.
