M18 Impact Vs. Rigid Stealth
Gharddog03
I quickly realized the m18 second generation fuel was the right choice for me 2753 is model number. I'm really liking this controlled fourth mode on the drill, using sheet metal screws all day, and it's automatic in slowing the impact way down when it needs to. That's normally not a problem but I didn't realize how much it became an asset until I start getting into tight cramped areas where I'm pushing on the impact at a crazy angle and trying to get the screw thru the material and it suddenly breaks through, and I'm not prepared for that and it won't let me strip the screw out.
you also might want to consider what other tools you may want to add in that battery platform, because it never is just an impact it will be other tools added eventually .......you don't want to have to many battery platforms to deal with unless you have to.
    Shiv Laser India
    Shiv Laser India
