repairing 1950s table saw
jon burgess
I have 2 question one how to take off my aluminum pulley the screw us out. I don't have much tools. My other question should I keep the bearing or get new ones? i believe that they are the original ones
its not letting upload a pic of the pulley but its on the motor.
get a pipe about same size as center of pulley, long enough to tap pulley farther down shaft, if you can..... sand shaft from where pulley is to end of shaft that it will come off of. .
I think any motor would work as long as it's at least 1/2 HP and same RPM. And the bolt holes lined up would be helpful, but not necessary
Although I know two motor shops around here I would want them to repair the motor to keep it original.
    Ballen1114
    Ballen1114
