redmed Posted April 19, 2016 Report Share Posted April 19, 2016 Why not take a few bucks and a few minutes and give it a try? 1 Quote Link to comment Share on other sites More sharing options...
KnarlyCarl Posted May 1, 2016 Report Share Posted May 1, 2016 Just got my set of hole saws and a larger single back.... These are Lenox hole saws, my favorite, and it cost $29 to sharpen the 6 piece kit plus the single 4-1/2" holesaw. Originally $80 for the kit and $37 for the larger single one . - The only possible problem is that when they sharpened them, they ground off the hook that Lenox comes with, i sure hope it doesn't diminish the performance, but that really took me back, I think that's one of the reasons they work so well, i'm going to be upset if they don't work like new... i have a new set to use when these went in to get sharpened and I will find out if they really make a difference. Although another problem is the kerf that might be lessened because the teeth are worn on the sides, giving me less clearance between the holesaw and the hole i'm cutting. I don't see any indication of adjustments to the teeth, although I'm sure the metal is too hard to bend them any further, and sharpening removes more material on the very tip, making that space even more narrow. Basically every other tooth is bent outwards and the other teeth are bent inwards to create space for the incoming body of the holesaw as it enters the cut, on carbide blades, this is accomplished by the carbide teeth, they are wider than the blade. WIth these hole saws, cutting more material off the tips to sharpen each tooth brings the tooth down closer to the body of the holesaw, leaving less room for the body of the holesaw to turn in the wood, because of build up of saw dust causing friction and resistance... Well mabe my next set will be carbide tipped holesaws! Here's what they look like new, notice the hook on each tooth Quote Link to comment Share on other sites More sharing options...
Kato Posted May 1, 2016 Report Share Posted May 1, 2016 If they messed with the offset it won't cut as well, and it won't stay "sharp" for very long. 1 Quote Link to comment Share on other sites More sharing options...
JimboS1ice Posted May 1, 2016 Report Share Posted May 1, 2016 I have the milwaukees another shot and they did pretty well, used 1 1/2" and 3 1/2" and they did well, just had bad luck with the one Jimbo Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
tonylandin Posted May 2, 2016 Report Share Posted May 2, 2016 A little unknown secret. Home Depot will replace a Diablo blade for FREE. Most Diablo blades say "Lifetime Guarantee" on the blade and or package. If you keep your receipts and packaging, simple exchange. Could be worth buying another if you don't have pkg or receipt and "trade" them out then you have two. Quote Link to comment Share on other sites More sharing options...
WigWagWorkshop Posted May 4, 2016 Report Share Posted May 4, 2016 Table saw blades no, but I will sharpen my bandsaw blades. -Steven Quote Link to comment Share on other sites More sharing options...
KnarlyCarl Posted August 2, 2016 Report Share Posted August 2, 2016 Took two blades to Ace hardware for them to sharpen, they did very nice job, for a grand total of @21.60 for both ... 1 Quote Link to comment Share on other sites More sharing options...
pancing Posted August 3, 2016 Report Share Posted August 3, 2016 yeesh, ive never paid more than 50 bucks for a blade, ive always used industrial hitachi blades ( not the ones you get stock in lowe's or menards) from amazon or special order from lowes. Quote Link to comment Share on other sites More sharing options...
