Foneguy Posted April 20, 2016 Report Posted April 20, 2016 **Disclaimer*** i am seeking advice, all safety procedures will be followed, along with an abundance of common sense ....... I am only doing the conduits and running wire now, not any hookups. I will be installing an RV outlet on the side of my house. Conduit is sealed 1" PVC. Length from panel to outlet is approx 25'. Needs are a 50amp RV outlet, along with a 20amp GFI outlet. I will most likely use an RV style service panel that has both outlets and breakers, similar to those in a campground. I will run a conduit out of panel and buried for any future needs. ?? What size wire is needed. I am thinking #4.. with a 70amp breaker THANKS Crew !!!!!!!
RickyMcGrath Posted April 20, 2016 Report Posted April 20, 2016 4AWG based on the info you provided. 4
Foneguy Posted April 20, 2016 Author Report Posted April 20, 2016 14 minutes ago, RickyMcGrath said: 4AWG based on the info you provided. Thanks Ricky !!! what app is that, please ? 1
RickyMcGrath Posted April 20, 2016 Report Posted April 20, 2016 Thanks Ricky !!! what app is that, please ? DeWalt Mobile Pro. 2
RickyMcGrath Posted April 20, 2016 Report Posted April 20, 2016 It has 145 different calculators pertinent to construction. It's pretty handy. 2
Foneguy Posted April 20, 2016 Author Report Posted April 20, 2016 4 minutes ago, RickyMcGrath said: It has 145 different calculators pertinent to construction. It's pretty handy. HAH !!!! Now I feel like a dumb ass !!! i have that app....... thanks for the help 2
Foneguy Posted April 20, 2016 Author Report Posted April 20, 2016 Looks like you added the electricians calculator pack ? i will use this more often now .....
JimboS1ice Posted April 20, 2016 Report Posted April 20, 2016 It has 145 different calculators pertinent to construction. It's pretty handy. I love that app 1
RickyMcGrath Posted April 20, 2016 Report Posted April 20, 2016 Looks like you added the electricians calculator pack ? i will use this more often now ..... I added the full master pack with all calculators. 1
BMack37 Posted April 20, 2016 Report Posted April 20, 2016 That is F-ing awesome! DL the app now, thanks
JimboS1ice Posted April 20, 2016 Report Posted April 20, 2016 That is F-ing awesome! DL the app now, thanks You will have to pay for different calculations, best bet buy them all! 3
noops Posted April 26, 2016 Report Posted April 26, 2016 You may be better off running 3/2 Al. 70A is a weird size and #4 copper isn't a common commodity. With 3/2 Al you can get NMD and strip off the jacket or run 3/2 ACWU. In any case a 1" conduit may be an unpleasant pull as I'm guessing you have 2 90s? A 20' U? 4 is as big as you can go in 1" pipe so if you could do 1.25" it would go smoother. Sent from my SM-G930W8 using Tapatalk
RickyMcGrath Posted April 26, 2016 Report Posted April 26, 2016 You may be better off running 3/2 Al. 70A is a weird size and #4 copper isn't a common commodity. With 3/2 Al you can get NMD and strip off the jacket or run 3/2 ACWU. In any case a 1" conduit may be an unpleasant pull as I'm guessing you have 2 90s? A 20' U? 4 is as big as you can go in 1" pipe so if you could do 1.25" it would go smoother. Sent from my SM-G930W8 using Tapatalk Most Lowes and HD carry 4AWG THHN by the foot. For a short run.....
Foneguy Posted April 26, 2016 Author Report Posted April 26, 2016 9 hours ago, RickyMcGrath said: Most Lowes and HD carry 4AWG THHN by the foot. For a short run..... I did a little re-engineering in my head... My needs were a lot less than I planned for, so I picked up some #6 ... wire not pulled yet, but I a sure this is going to be fine ... thought I had a pic, will post it later
