Ben74 Posted August 18, 2018 Report Share Posted August 18, 2018 Hi I recently purchased a makita 18v drill and impact driver combi set. The chuck tightens with a series of small clicks but in the last few days it tightens still with a series of small clicks but now gives a quarter turn or so as it’s being tightened. So you get a series of clicks as it tightens then a sudden give and the chuck turns freely for a quarter turn or so then catches again and continues tightening with a series of clicks. The clicks fell like a solid racket but the give as it tightens feels wrong to me. Does anyone have any experience of this. The other problem I have had is that if I drive a screw in with the combi drill then stop and put it into reverse and pull the trigger to back the same screw out it makes a nasty noise as if some gears were crunching and doesn’t transmit any power to the screw driver bit. If I take my finger off the trigger and then put the power back on it engages as normal. Any advice would be appreciated. Quote Link to comment Share on other sites More sharing options...
