Steve27 Posted June 12 Report Share Posted June 12 (edited) Hello, I'm having an issue with putting a new assembly rod locking mechanism on my used DeWalt 734 planer. The assembly rod locking mechanism prevents the cutter heads from moving via vibration/cutting. It helps prevent snipe. Anyway, I have the correct part number and part. The old part was beat up and not useful for a template on how to install the new part. The main issue is the when the part is laid flat, it is too long to easily install. If I screw the part via the 4 clips into the 4 pole areas, the part pushes up into an inverted V position. That issue makes it so high, that I can't put the cover back on. And the knob the controls the depth of the cut, doesn't fit appropriately. If I try to push down on the locking mechanism, I will end up damaging 4 the clips that are screwed into the 4 posts. The assembly rod locking mechanism does have springs, so I am assuming the springs need to be compressed before the install. But I don't have a clue how to do that. Any advice would be appreciated. Thanks, Steve. PS Please see the attached pictures. Edited June 12 by Steve27 Add picture examples Quote Link to comment Share on other sites More sharing options...
