rrich1 Posted August 9, 2018 Report Share Posted August 9, 2018 I started my son's chest of drawers and night stand today. These will match the hamper I made in back in March. It will be a cherry frame with walnut sides and drawer fronts. I didn't get a pic of all the wood and me trying to figure out which pieces will come from what boards. From the 8/4 boards I figured out the best layout that would yield me the best excess material. A few cuts got a little close so hopefully I meet all of my dimensions. After layout, which took forever, I cut the pieces out on the bandsaw. I wanted to leave as few pieces as possible so that I wouldn't be wasting wood off the bat but I decided to cut each piece out. Doing this I should eliminate any surprising twist after I let these sit for a day. Wood stress usually happens when cutting thick boards so hopefully if any movement happens it occurs now and not after final dimensioning. Pic of the hamper for example. Sent from my Pixel XL using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
rrich1 Posted August 10, 2018 Author Report Share Posted August 10, 2018 2hrs of jointing and planing and everything pretty much looks the same...ugh. up next is cutting to length and starting the mortises. Sent from my Pixel XL using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
rrich1 Posted August 24, 2018 Author Report Share Posted August 24, 2018 No shop time the past week. I had to help my mother move out of her house. I got half of the Domino's mortised out. Each joint still needs one more cut. I couldn't help myself and had to out it together to get the feel of the size of the pieces. Hopefully tomorrow I'll get the other mortises cut. Sent from my Pixel XL using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
rrich1 Posted August 25, 2018 Author Report Share Posted August 25, 2018 Second set of mortises cut. Up next is the grooves for the side panels and I have to make a jig to route out the mortises for the web frames. Into the legs. Sent from my Pixel XL using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
rrich1 Posted August 28, 2018 Author Report Share Posted August 28, 2018 Today I got the panel grooves cut for the nightstand. Tomorrow I'll get the chest of drawers done. Then make the jig to route out for the web frames to insert into the legs. Sent from my Pixel XL using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
rrich1 Posted August 30, 2018 Author Report Share Posted August 30, 2018 More progress today and a setback at the same time. I did a dry fit of the pieces again and realized I didn't route out the dado for the top panels. I'll need to set the router table back up and do that. I did manage to make the jig for the router to route out the spaces for the web frames to insert into. Next I started to work on making the panels. The walnut was all the at the bottom of the cherry pile so I had to dig them out. The plans call for 1/2" but my walnut is slightly over 1" now. With resawing, jointing, and sanding I believe I can get 3/8" and I'm fine with that. The boards I have are over 11" wide so to joint them I had to rip them down the center. This will give me an extra glue joint but it will be fine. Those two pieces got resawn and are currently in two sets of clamps. I'll run them through the drum sander to get them closer to equal thickness for the final glue up. Reason for me doing it this way is the bandsaw wasn't perfectly centered on the board so it would be hard to get cauls to work to keep one face flat of the other sides are not equal. Sent from my Pixel XL using Tapatalk 3 Quote Link to comment Share on other sites More sharing options...
rrich1 Posted August 31, 2018 Author Report Share Posted August 31, 2018 Solid progress today. Could have been more but I needed to mow the lawn. Last night I got the chest of drawers top panel pieces glued up. Today I got the rest of the panel pieces cut, ripped on the band saw, jointed, planed, and are resting right now. Tomorrow hopefully I can get these resawn on the band saw and get a few pieces glued up. If you do the glue up right they essentially look like a larger piece that was resawn and bookmatched for the panel. Each panel takes two pieces that have to be resawn to get the width that is needed and save on waste. Sent from my Pixel XL using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
rrich1 Posted August 31, 2018 Author Report Share Posted August 31, 2018 Resaw day today. I resawed the rest of the panels and drum sanded one panel to get them relatively flat so cauls to keep the joints flat in glue up. I might try and do another when I get home tonight but I have to work OT tommorow at the illini football game. If you haven't gotten at least a few hand planes I highly recommend them. The saw marks were not very good for glue up. A few passes with the LAJ and they were glass smooth. Sent from my Pixel XL using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
rrich1 Posted September 7, 2018 Author Report Share Posted September 7, 2018 Been a while since an update. All of the panels are glued up, sanded to 180, and cut to length. The night stand panels have the rabbets cut and everything fit into place. The rear panel is made of maple ply and will be painted like the hamper I already made. Right now I am working on the rabbeting the panels for the chest of drawers. I'll finish those and cut the rear panel tonight after work.If you don't have a cabinet scraper I recommend one. They work great to clean up glue joints. Also the other day my drum sander conveyor belt broke. Luckily I ordered a new one and it arrived the previous day. I took the time to clean up the rusty metal pieces to clean everything up. Up next is the web frames. Sent from my Pixel XL using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
rrich1 Posted September 8, 2018 Author Report Share Posted September 8, 2018 Chest of drawers is up. And the main pieces are fitted. Up next is sanding everything. Then I will glue the sides together. This will help me get better measurements for the web frames. I purchased some total boat clear epoxy and it arrived yesterday but it is missing one of the pumps. Sent from my Pixel XL using Tapatalk 3 Quote Link to comment Share on other sites More sharing options...
rrich1 Posted September 9, 2018 Author Report Share Posted September 9, 2018 The night stand is sanded to 220 with a seal coat on. I'm loving this air dried walnut. It really pops with the finish on it. The dresser frame is sanded at 150. I still need to sand the panels. I think I am going to wait until Monday for the sides to be glued/epoxied together. I want to buy some thickener for the epoxy so it won't be so runny. Sent from my Pixel XL using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
rrich1 Posted September 11, 2018 Author Report Share Posted September 11, 2018 So I got everything sanded...which took a while. Last night I attempted to glue up the night stand sides but I messed up the epoxy ratio as I didn't have both pumps. Today I tried to clean out the epoxy that didn't set up and weighed out the epoxy this time. I only did one of the sides of the night stand. Wasted epoxy but if this works I will go ahead and do the other side of the night stand and chest of drawers Sent from my Pixel XL using Tapatalk 3 Quote Link to comment Share on other sites More sharing options...
khariV Posted September 14, 2018 Report Share Posted September 14, 2018 You use epoxy for glue ups? Why not titebond? 1 Quote Link to comment Share on other sites More sharing options...
rrich1 Posted September 14, 2018 Author Report Share Posted September 14, 2018 You use epoxy for glue ups? Why not titebond?Khari good question. The reasons why I went with epoxy are:1. Longer open time than yellow glue. 2. I have never used epoxy before and wanted to try it.3rd and most important it is gap filling. Even with the Domino's I had to shave a little off of some of them to get fitted flush on the bottom and top of the pieces. The epoxy will fill those gaps and hopefully give me a stronger joint than if just normal glue. 4. Marc did it in the vid and I have to be cool like him.Sent from my Pixel XL using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
khariV Posted September 14, 2018 Report Share Posted September 14, 2018 Interesting. I might have to read up on this to address some of my own "well, that doesn't quite fit as tightly as I'd like" joints. My only concern would be getting it everywhere as the two kinds of epoxy I've got (West and SystemThree) are so runny, it'd make an unholy mess. Quote Link to comment Share on other sites More sharing options...
rrich1 Posted September 14, 2018 Author Report Share Posted September 14, 2018 Interesting. I might have to read up on this to address some of my own "well, that doesn't quite fit as tightly as I'd like" joints. My only concern would be getting it everywhere as the two kinds of epoxy I've got (West and SystemThree) are so runny, it'd make an unholy mess.I bought some 404 filler as well. This thickens it up. Add as much as as little to get the consistency you want. https://www.rockler.com/west-systemreg-epoxy-fillerSent from my Pixel XL using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
khariV Posted September 14, 2018 Report Share Posted September 14, 2018 3 minutes ago, rrich1 said: I bought some 404 filler as well. This thickens it up. Add as much as as little to get the consistency you want.https://www.rockler.com/west-systemreg-epoxy-filler Sent from my Pixel XL using Tapatalk Wow - I'm such a nub. I wish I had known about this when I was using epoxy to repair water damage on laminate countertops at a cat shelter I volunteer at. As it was, the thin epoxy ran everywhere and made a colossal mess that I had to clean up. Quote Link to comment Share on other sites More sharing options...
rrich1 Posted September 14, 2018 Author Report Share Posted September 14, 2018 Wow - I'm such a nub. I wish I had known about this when I was using epoxy to repair water damage on laminate countertops at a cat shelter I volunteer at. As it was, the thin epoxy ran everywhere and made a colossal mess that I had to clean up.Ha! I'm obviously new to it as well. The pump came yesterday but I didn't have time to glue anything up last night due to getting out of work late. I'm picking my son up from preschool here soon and will get them glued up while he is eating lunch. Sent from my Pixel XL using Tapatalk Quote Link to comment Share on other sites More sharing options...
rrich1 Posted September 14, 2018 Author Report Share Posted September 14, 2018 @khariV here is a pic of the epoxy with the adative. I could have put more in it but felt that was as far as I wanted it to go to not be a paste. I got the other side of the night stand glued and one side of the chest of drawers before the epoxy was too stiff. If I double checked all my Domino's on the chest of drawers before hand I could have probably gotten to both sides. Oh well. I'll do the other side before work or after. I won't get to work on these again until Sunday anyways. On Wednesday I did get all of the web frame material jointed and planed. Will cut to final dimensions when these panels are glued up. Sent from my Pixel XL using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
rrich1 Posted September 15, 2018 Author Report Share Posted September 15, 2018 Last side panel is epoxied and in clamps. I also filled two knots with black tinted epoxy. Those were on the top panel of the night stand. Sent from my Pixel XL using Tapatalk Quote Link to comment Share on other sites More sharing options...
rrich1 Posted September 17, 2018 Author Report Share Posted September 17, 2018 Big progress today. I was able to get a few hours of shop time in after church and after the in laws came over for supper. Today I was able to get all of the web frames cut out and dimensioned. Somehow I originally miscounted the sides of the frames and was short by 4. I had to dig around for scrap and I was able to find some pieces of cherry that would work. I didn't feel like cutting up a piece of lumber which would have been quicker. Up next is to domino all of the jointed of the web frames and glue them up. With the domino basically being a router I don't like to run it so late at night. I'll then be able to get it back to my friend since I have had it a month. Lol . If you look close the front and rear pieces have tennons cut out of them. This is what took these so long to make. Tomorrow I will also paint the back panels so I could theoretically glue these things up on Tuesday or Wednesday. Sent from my Pixel XL using Tapatalk Quote Link to comment Share on other sites More sharing options...
rrich1 Posted September 19, 2018 Author Report Share Posted September 19, 2018 Went frames made and the pack panels are painted. Tonight after work I made the runners that the drawer slides on. I also started to round over the mortises of the web frames. These slide into the slots of the chest of drawers and night stand legs. Sent from my Pixel XL using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
rrich1 Posted September 19, 2018 Author Report Share Posted September 19, 2018 Glued and nailed on the runners today. The night stand fit on the first try. I also put another coat of paint on the backs. Getting a lot closer! I could have gotten more done but I started a side project yesterday. A doll bunk bed for my daughter. Making it out of left over hickory from the workbench build. Sent from my Pixel XL using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
rrich1 Posted September 21, 2018 Author Report Share Posted September 21, 2018 Dry fit. Glue up will commence after work tonight. Sent from my Pixel XL using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
rrich1 Posted September 22, 2018 Author Report Share Posted September 22, 2018 Hopefully I didn't forget anything. Night stand is epoxied together. I cut the lower runner but haven't attached it yet. Sent from my Pixel XL using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
