135 -
Posts posted by Astro_Pneumatic_Tool_Co.
Happy Friday everyone!
Our friends at Jacko have an AMAZING sale on their Magnetic Bluetooth Speakers via touchofmodern!
Click the link below to take advantage of this incredible savings while they last!
https://touchofmodern.com/sales/jackco/sound-magnetic-bluetooth-speakers -
Astro's new 21FX 21 LED Waterproof Flex Light With Magnet is ideal for working under the hood, changing a tire, wiring a home theater, or switching on a breaker in your home fuse box. The base magnet and hook ensure ease of mounting and it is great to have in case of emergencies. The potential uses of this light are endless. It can be bent, folded, and wrapped/hooked around objects. The user can place it on a flat surface for use as a freestanding light, or adhere it to most metal surfaces for convenient use. The bright light beams exactly where you need it to, providing maximum visibility. This light is composed with waterproof silicone, and has 3 different settings (7 LED Strip, 21 LED and 21 LED flashing). These settings can be activated by pressing the on/off button. This light is perfect for hands-free use and requires 3 AAA batteries.
(800) 221-9705
cbarakat@astrotools.com
http://www.astrotools.com -
Its about time for another amazing Woot.com sale!(800) 221-9705cbarakat@astrotools.com
Astro's new 1822 ½" Nano Impact is the latest in miniature lightweight impact development. At only 3.85" long (or about 1/2" longer than a credit card), the twin hammer 1822 Nano Impact is deceivingly powerful, registering a max of 450 ft/lbs of torque. The 1822 was designed to be extremely light (3.0lbs.) and well balanced when connected to an air line, and operates in 3 forward and reverse speeds. Featuring a twin hammer design for increased reliability, and coming from Astro's robust ONYX line, this impact has more than just the numbers behind it.
It is in stock now, so make sure to contact us if you need a distributor referral! -
Check out some information on our newly redesigned Suction Cups, Item # 9038 - Single Suction Cup AND Item # 9039 - Double Suction Cup. These suction cups are built with a lever lock system to ensure a secure grip. They are ideal for one person auto glass repair, and can also be used for small dent removal. They are constructed of a high impact plastic, allowing for sturdiness and durability.
(800) 221-9705
http://www.astrotools.com/
Have a great day! -
that damaged socket head cap extractor set also looks pretty cool to have!
Glad you like it!
Check out the video we put together showing how this set is used properly.
Welcome back to the office folks.
To kick off the week, Woot.com is having an AMAZING promo on a few Astro items, so make sure you take a moment to check them out!
http://tools.woot.com/plus/astro-pne...e?ref=cnt_wp_4
(800) 221-9705
Have a great week! -
Hope the day goes by nice and smooth for all!
Check out some information on our newly added Radiator Pressure Tester Caps, Item # 7858541 - No. 41 Radiator Test Cap (for Late Model GM and Ford) AND Item # 7858542 - No. 42 Radiator Test Cap (for Late Model BMW and Land Rover). These test caps work with the Astro Pneumatic 78585 Universal Radiator Pressure Tester and Vacuum Type Cooling System Kit. They are constructed for long lasting use.
(800) 221-9705
http://www.astrotools.com/index.php/catalogsearch/result/?q=78585 -
Check out our Item #2185 - Long Double Cut Carbide Burr Set 4.5".- 1/4" Shank- Composed of Tungsten Carbide- Extra-long 4.5" in length for hard to reach areas- Should not exceed a maximum of 20,000RPM(800) 221-9705cbarakat@astrotools.com
Check out our Item # 9421 - Multi-Angle Internal/External Snap Ring Pliers.- Engineered for professional use, tips made from heavy-duty C45 Tool Steel- Quickly change out tips or from internal to external use- Three interchangeable sizes of 270 degree adjustable and locking tips- Tool and tips both feature machined teeth to prevent movement once angle is set- Firm and positive internal to external adjustment(800) 221-9705cbarakat@astrotools.com
Good Morning Everyone,
Let's take a closer look at one of our hot new tools!
Item # 7763, the Astro Digital LCD 12-24V Circuit Tester.
This tool has a clear LCD display for accurate voltage readouts. It has a small, ergonomic design for easy use in confined areas, and is great for use on cars, boats, trailers, vans, RV's, motorcycles, airplanes and snowmobiles. It is used to check electrical circuits and accessories on all 12~24 volt systems. The needle-sharp stainless steel probe allows for easy piercing. Cable length : 11ft; Voltage : DC 12-24V.
http://www.astrotools.com/index.php/new-products/digital-lcd-12-24v-circuit-tester.html
800) 221-9705
cbarakat@astrotools.com -
Below please find information on some BRAND NEW items that we are bringing into our product line. These items feature innovative developments in the evolution of tried-and-tested tools. They are all composed of high quality, durable materials, providing dependability and longevity of use. These items will be available by the end of February/early March, and are sure to move quickly!
(800) 221-9705
Great end user video utilizing some of the Astro Top Sellers to debadge and rebadge aMustang 5.0 in minutes!
https://www.youtube.com/watch?v=iAE-GHqnZN8 -
Good Morning everyone!
Hope all of us had an amazing weekend, and are ready for an even better week!
We are receiving a ton of new items in the coming months, so make sure to keep an eye on the "New Products" section of our website for all the info you will need!
http://www.astrotools.com/index.php/new-products.html
(800) 221-9705
Good Morning!
Check out some information on our 500HWA - NEW and IMPROVED Heavy Duty ½ Ton Capacity Telescoping Transmission Jack. This jack is ideal for under-hoist use. It is Taiwanese made with a double-piston construction, along with durable professional grade seals for all-day/everyday use. Featuring parts that have been CNC precision machined, this jack is perfect for high use industries that demand the best quality and longest lasting components. It is equipped with a fully adjustable universal saddle, safety chain for alignment of bolt patterns, and a foot operated pump and lowering pedals which allow use of both hands to position and align the saddle. This unit meets ANSI Standards for performance and safety.
(800) 221-9705
Good Morning everyone!Check out our High Quality Backing Pads!These backing pads are great for detailing vehicles, and offer excellent edge flexibility allowing the user to maximize the area detailed. They function great with DA Random Orbit Sanders, and are composed of long lasting, durable polyurethane. They are in stock, and ready to ship!(800) 221-9705cbarakat@astrotools.comwww.astrotools.com
Want to get all of the newest product updates from Astro Pneumatic Tool Co.?Click on the link below and sign-up for our e-mail list to make sure you get all the details on hot new products!(800) 221-9705cbarakat@astrotools.comwww.astrotools.com#Astro #Pneumatic #Tool #Company #Deals #Savings #LowPrices #January #NewYear #Fall #Follow #Like #Share #RT #Click #Shop #Automotive #Aftermarket #Tools #Website #Opinions #New #Improved #FRIDAY #SignUp
Check out our Must Have Jump Starters! Great for anyone who may need a jump for your car, charge for your devices, or just some extra power for your laptops!
(800) 221-9705
http://www.astrotools.com/index.php/catalogsearch/result/index/?cat=257&limit=12&q=jump+starter -
Morning all,
Hope everyone had a great weekend!
Woot.com is holding a great promo on the Astro 55600 - 2 in 1 Workbench Table / Scaffold.
This item provides a wide variety of features and capabilities
The tool tray is designed to hold hand tools, fasteners and standard paint cans.
Take advantage of this great deal and get yours now!
http://tools.woot.com/offers/2-in-1-workbench-table-scaffold-1?ref=cnt_dly_img -
That is a cool belt sander.
check it out online!
http://www.astrotools.com/index.php/air-belt-sander-1-2-x-18-with-2pc-belts-80-100.html
Good morning all and Happy New Year!
We hope it is off to a great start for all of our Astro fans!
Check out some info on our Astro 7785 Portable 650A Diesel Jump Starter/Power Supply with Macbook Power Cord. Supports 12V vehicle jump start and charges most electronic including: cell phones, PSP, MP3/MP4, PDA, Notebooks, car refrigerators and more.
This great item will be available this month, so keep an eye out!
http://www.astrotools.com/index.php/portable-650a-diesel-jump-starter-power-supply-with-macbook-power-cord.html
(800) 221-9705
With the year wrapping up, we just wanted to thank all of our fans for your continued support throughout 2014.
In the coming year, we will remain committed to bringing you the highest quality tools!
Thank you, and Happy Holidays to you and Yours!
(800) 221-9705
cbarakat@astrotools.com- 2
Astro Tools | Woot Deal!
in Tool Deals
Good morning folks!
A little over 24 hours left in our Woot.com deal!
Make sure to click the link below and check out the amazing savings!
http://tools.woot.com/plus/april-astro-pneumatic-tools?ref=cnt_wp_11
Have an amazing week!
(800) 221-9705
