fishnaked
40 -
Posts posted by fishnaked
8 hours ago, framer said:
if the wheel is heavy or the motor slows down quickly, the wheel inertia loosens the nut. does the motor slow down quickly when you shut it off? perhaps bearings are going out.
are you using the wrench to tighten the nut?
The motor doesn't seem to slow down any quicker than it did when new...or any quicker than my other grinders. It runs smooth... and has about an hour on it or less.....so I don't think the bearings are going out. And yes, I'm using the wrench. Makes little difference how much muscle I put into the wrench either.
12 hours ago, method said:
I thought dewalt nuts have a clutch in them. Have you tried a different nut? It may be faulty.
I'm not familiar with nuts with clutches in them. This one just has a plain ol' nut. Nothing fancy.
On 1/27/2019 at 12:07 AM, framer said:
turn it off while the disc is applied against a surface.
I started doing that towards the end of my last session with it. Works but is a pain in the rear having to retrain myself to use a grinder like that. Shouldn't have to. I contacted Dewalt but have heard nothing back.
Thanks. Hope I can figure this out as the grinder isn't of much value to me if the disc comes off every time I shut it down. Very frustrating.
I really like this grinder. However, after roughly only an hour of use, it has developed this habit of the grinding disc spinning off...AFTER I stop grinding and place the tool down. As it is decelerating, I can just watch the nut spin loose...spinning its way right off the grinder.
It didn't do this when I first started using it. I thought that perhaps I had something on wrong. I've looked and see nothing obvious. I'm not new to this. I have a Makita and Metabo grinders as well. No problem. I've also used a variety of other grinders over the last 30 years. No problem like this before. I keep thinking it has to be something simple yet I see nothing. I tighten the nut as tight as I can with the included allen wrench. Makes no difference. I'm using the grinding disc that came with it. A cut off disc doesn't come off as often but...it does some times. I have no issues using sanding flap discs on it.
Anyone experience this before? What's the solution?
Funny as I came here to the forum for the same issue with the same jig saw. I haven't contacted Bosch as I figured they'd tell me what they told you.
I'm very bummed as I haven't used this saw hard nor have I used it a lot. And I like it.
Did you find an answer to your question? Or does anyone reading this have any idea what might be wrong?
Thanks, guys! What is it about the Metabo that makes it the best?
I've had a Makita 4" grinder since 1984 that's still running strong. In need of something larger, I borrowed a friend's older Metabo 6" with twist handle. I like it so much, I don't want to give it back! Super smooth, not too big, and perfect power
A grinder this size will make my life a lot easier and open doors to how I do many projects. After using this twist handle, I've made up my mind that feature is a must for me. I looked at the 7" Ridgid at Home Depot and it feels good in hand. $129. The reviews seem a little mixed though. I can get a new 7" Metabo W24-180 for $189.
This is a tool I would not use day in and day out. But I appreciate quality and a tool that runs smooth... yet I am not a man of large means. Is the Metabo worth $60 more than the Ridgid?
Any insight and/or opinions would be appreciated. Thanks! -
Seriously though.....a good jigsaw (like the Carvex) with a guide (can make one yourself or buy one relatively cheaply) and you'll be right as rain while you fish naked!
Thanks. I did just that this morning. Made myself a guide that screws to a 10' long 2x4 which will be my compass. The decking I am cutting runs over some joist I don't want to cut so I also built a wood spacer for my jig saw so that it will only cut 1.5" deep. The Carvex looks nice. I have a pretty nice Bosch with some agressive cutting blades. Shouldn't take too long....I hope. I'm gonna get naked if this works as smoothly as I hope!
Thanks for all the replies, everyone!
This guy is able to, unless I am misunderstanding. I've seen a demo where they cut about a 3' radius when we had a new blade come out a few years back.
Thanks for that! I haven't tried plywood but I can see how it would work being that it's so thin. The depth of the 2x6 is what's getting me. If someone could do that, I'd love to see it! :-)
Jigsaw?
Thanks. That's what I'm leaning towards at this point.
Thanks. I decided to try on a test piece....a 2x6. First attempt, I set the saw depth at 1 1/2". Did not work. I then set it at ~3/4". Worked very poorly. On my last attempt, I set the depth at ~3/8". Worked better yet but still poorly. Don't know what to do now if a local store doesn't happen to carry the Arcus blade. I have a 20' diameter deck to cut out on Sunday.
Is that radius big enough to not bind up a 7 1/4" blade?
Just purchased a generator for a one time off-grid yurt project in the mountains requiring the use of a DeWalt 12" sliding miter saw, 15 amp. That's my biggest power tool I'll be using on this project....and since I'm mostly solo, there will be no other tools run at the same time as the miter saw. One tool at a time.
Given that I only needed a generator for this one job, and I'm on a tight budget, I didn't buy an expensive one: DuroStar DS4000S, 7HP...4000 peak watts, 3,300 rated watts. Got good reviews. Paid $300.
I've never used a generator before. Know nothing more than a couple articles I read. Figured this DuroStar would be overkill.
At 15 amp, 120V, my miter saw would need 1800 watts...and a max of 3300 according to this article http://www.toolsofthetrade.net/jobsi...generator.aspx .
Runs my smaller tools great. Even runs my 15 amp circular saw as if it were plugged in to my shop outlet. HOWEVER, when I run my miter saw, it seems to take longer for it to build up its RPMs. It just doesn't seem quite the same as when plugged in to my shop outlet.
Is this normal? Am I going to mess up my miter saw? I need to figure this out soon. Starting this project this Saturday.
4011 angle grinder: Why does the grinding disc keeps spinning off?
in Dewalt
Thanks. I thought I was being clever for doing that too. Unfortunately, it didn't make a difference. This thing has me baffled! I wish DeWalt would get back to me....
