stefano Posted February 17, 2021 Report Share Posted February 17, 2021 hello all, I have a 50 Litre Direct Drive Air Compressor - 9.6CFM, 2.5HP 50L and I want to get a small sand blasting cabinet which states Air consumption - minimum 10 cfm at 8 bar Min. Air Requirement: 80-100 psi https://www.sgs-engineering.com/ssb100-shot-blast-cabinet this would be for occasional use to clean up the surface of small items i don't mind if it cuts out and the compressor needs recharging like every 30 seconds, if it means i can keep using the compressor I have as it's pretty new and I don't have space for a 100L one can anyone tell if it would work or just not work at all ?! thank you, stefano Quote Link to comment Share on other sites More sharing options...
