ryobi miter saw turntable not level
guyfoxday
I recently picked up a Ryobi 10 in. Compound Miter Saw 14amp and while I understand how to make all the blade and fence adjustments, the actual turntable is not precisely level with the base (the non-turnable "no hands area").  On the left side the difference is about 1/16 inch so that when i clamp a board, it doesn't sit level on the turntable and the cut is ever so slightly off.  Anyone know how to make this adjustment?
Thanks
  • 5 months later...
I have the same issue and do not have an answer but, I am going to try to turn the entire saw upside down to see if there is any excess sawdust or other wood shavings that might be raising the turntable portion as it is slightly higher than both no hands sides.  Sounds very similar to your issue.  I see that no one has answered this yet.  Maybe someone reading this may have some other thoughts.
  • Confused 1
    jucetgc
    jucetgc
