kanxrus
1,145 -
1
Posts posted by kanxrus
I'm building my own inserts out of Fastcap's Kaizen foam. I've been quite happy with it.
Do you have any photo's to share?
These are the Sanyo cells. Interesting that you would find green (Sony cells) in a DCB204. I have yet to see a single Sony cell in the slide pack batteries.
HERE IS ANOTHER LOOK INSIDE.
- 3
Did you get this fixed? I can assist you in the re-assembly if you are still in limbo.
Not sure which one is causing you the problem. I would exchange out the entire kit if within your purchase grace period. Or drop it by your local service center.
The blinking is to let you know the battery need's charging. The batteries are designed to handle large loads from various power-tools. The flashlight run's the battery down very slow. Lithium batteries have a threshold at which they have a point of no return. Meaning, drain them to low and they cannot be recovered.
Once the light flashes, remove it and recharge the battery.
If you purchased this used, it is a very likely the tire's have worn it's course. Replacement ones run around $6. You did adjust tension properly?
You have a lot of variables in this equation that may not have just one answer. Your best bet, is to either exchange the entire kit, or take it to your local service center and have them look the system over.
Look's like some tweaks to the current model's. I like a lot of the new features.
Sorry about that, I fixed it. Do you have any more info about the new radio? I have yet see one, let alone hear it.
Everybody has teamed up with the typical battery manuf. Dewalt is using the newer HC Sanyo cells, Bosch and Milwaukee are using the HC Samsung sells. Makita... who know's what they have up their sleeve with Sony. Panasonic is doing their own cells at 4.2ah.
Could be the brushes, if they are worn down and/or spring's not applying proper amount of pressure. I'd rule that out first, as it is the easiest and cheapest repair.
Great stuff, thanks for sharing!
Again, this was a promo from 2011.
It's no surprise, Metabo already launched 4.0ah batteries this year. I'm sure Makita, and Milwaukee have something in mind this year as well.
DEWALT® Launches Comprehensive Dust System to Help Mitigate the Dangers of Long-term Dust Exposure on Professional Jobsites.
TOWSON, Md. (April 9, 2011) – Today, as part of its commitment to improving the jobsite work environment, DEWALT announces the launch of a new system of tools designed to reduce workers’ exposure to dust and its harmful effects. The system includes three hammer shrouds, two grinder shrouds and a vacuum connector system that will combat dust inhalation associated with concrete cutting, chipping and drilling applications.
According to the Occupational Safety and Health Administration1, silica exposure remains a serious threat to nearly 2 million U.S. workers. Contractors who breathe in crystalline silica dust are susceptible to silicosis, an incurable respiratory disease that can be disabling or even fatal in severe cases.
“We recognize that we have a role in helping to make jobsites as safe and productive as possible,†said Jeff Beck, product manager, DEWALT. “Dust and crystalline silica exposure is a serious issue facing many contractors today. Our new dust collection system, along with our current dust extraction products, will help to protect users and allow them to feel confident in the tools they require to earn a living.â€
Hammer Shrouds;
DEWALT has created a new line of hammer shrouds that help reduce airborne dust created by hammer drilling, chipping and demolition of concrete.
The Hole Drilling and Cleaning Hammer Shroud (DWH050K) offers two interchangeable drilling heads ? one for holes up to 1-1/2 inches and one for holes up to 2 inches ? to extract the dust created from drilling. The product is equipped with a tough rubber seal that adheres to most masonry surfaces when activated by a vacuum suction. The DWH050K also includes 5/16-inch and 9/16-inch hole cleaning tubes used to extract the dust from holes prior to applying epoxy for chemical anchoring. This kit is compatible with all DEWALT hammers and hammerdrills.
The Demolition Hammer Shroud (DWH052K) is used with DEWALT demolition hammers and pavement breakers to help extract particles and dust created in heavy demolition applications. The shroud is compatible with the D25980 and D25960 hammers and can be used with pointed and flat chisels up to 1-1/4 inches.
The Chipping Hammer Shroud (DWH053K) is compatible with all DEWALT SDS MAX hammers and the D25553K, D25651K, D25831K spline drive hammers. It is used to collect dust particles created in chipping applications and includes three different sized end nozzles to allow the user to match the chisel length to the nozzle length, providing the maximum amount of dust extraction.
The hammer dust shrouds are currently available through independent distributors. The products are expected to retail for $99.00 (DWH050K), $89.00 (DWH052K) and $109.00 (DWH053K).
Grinder Shrouds;
Concrete and masonry removal, cutting and grinding are some of the heaviest dust creating applications for users. To address this concern, DEWALT has introduced a surfacing shroud and a cutting/tuck pointing shroud.
The 5-inch Surfacing Shroud (DWE46150) is ideal for contractors specializing in remodeling, restoration, painting, flooring, and concrete forming and finishing. The shroud has a tool-free shroud adjustment and wheel removal when using the backing flange, as well as a rotating edge door allowing for flush edge grinding. The 5-inch Surfacing Shroud will be sold independently (DWE46150) or as a kit containing the shroud, a small angle grinder, 5-inch diamond turbo cup wheel and universal vacuum hose connector (DWE46151).
The 6-inch Cutting/Tuck Pointing Shroud (DWE46100) is ideal for restoration contractors, brick masons, water proofers, tuck pointers and general contractors. The product features a tool-free tool clamp allowing for adjustments without a wrench or screwdriver, as well as a 1.7-inch depth of cut for a wide range of uses. The DWE46100 uses up to a 6-inch blade and has a cornering feature, which captures a high volume of dust particles while still performing difficult inside corner cuts. The 6-inch Cutting/Tuck Pointing Shroud will be sold independently (DWE46100) or as a kit containing the shroud, a high performance grinder, diamond wheel and universal vacuum connector (DWE46101).
All products will be available in July 2012. Expected retail values are as follows: $69.00 (DWE46150), $199.00 (DWE46151), $129.00 (DWE46100) and $249.00 (DWE46101).
Universal Connector System;
DEWALT’s new universal connector system, which complements the new shrouds, features nine individual adaptors that work with all grinding, drilling, chipping and demolition tools currently on the market, regardless of brand. A quick connect hose attachment (DWV9000), which provides a positive lock and allows the hose to swivel, replaces the existing hose connection on grinding and hammer shrouds. The DWV9000 will be available in June 2012 and retail for approximately $19.99.
DEWALT’s new dust collection system will join the company’s existing line of dust extraction tools, including a Dust Extraction for L-Shape SDS Hammer (D25300DH), 36 Volt SDS Rotary Hammer Kit and Dust Extraction System (DC233KLDH), Dust Extraction System for 36 Volt SDS Rotary Hammer (D25302DH) and a Dust Extractor Telescope with Hose for SDS Rotary Hammer (D25301D). DEWALT also currently has several vacuums including a 10 Gallon Dust Extractor Vacuum (D27095H), 10 Gallon Dust Extractor with HEPA Filter (D27095H) and a 12 Gallon Dust Extractor with Automatic Filter Clean (D27904).
All of the products outlined above come with a three-year limited warranty, one-year service contract and 90-day money-back guarantee.
About DEWALT;
DEWALT is a leading manufacturer of industrial power tools and accessories, including corded and cordless drills, saws, hammers, grinders, routers, planers, plate joiners, sanders, lasers, generators, compressors, nailers, saw blades, metal and masonry drill bits, abrasives, screwdriving accessories and more. DEWALT tools can be found nationally and internationally, wherever tools are sold. With more than 1,000 factory-owned and authorized locations, DEWALT has one of the most extensive service and repair networks in North America. For more information, visit www.dewalt.com or follow DEWALT on Facebook and Twitter.
Summary;
* When compared to similar tools on the market
1 Occupational Safety & Health Administration, “’Crystalline Silica Exposure’ Health Hazard Information for General Industry Employees†http://www.library.csi.cuny.edu/dept/history/lavender/footnote.html (2002)
DEWALT has contacted us to invite our members to participate in the "Chopsaw Blade Experience" (this is what we are calling it). They are looking for serious metal worker's who use a chopsaw on a normal basis to participate.
The skinny;
DEWALT has a new diamond chop saw blade that lasts 100 times longer than a standard blade. This new blade is going on tour around the USA to people who constantly use a chop saw to cut metal. Each participant will use the new blade for one week, complete a video testimonial and send it to the next person.
For your time, Dewalt will be offering some give-away's. Detail's to follow.
More detail's to follow. For now, if you are a serious metal worker, and you are interested in participating. Please mention it in this topic. Later when we have all the information, we will contact you.
i might have believed this test had the tester newly opened both packages in front of the camera. who knows what kind of tampering he did to the bits, for example he could have easily removed the temper or hardness of the steel with a regular flame torch.
Protoolreviews.com called me out when I did this test, after doing their own independent testing, they drew the same conclusion that I did. I took before photo's of the tip's, that's why they were out of the package.
Sorry, but that is the dumbest thing I've ever seen! WTH Makita!?
Dewalt just re-launched their promotion page. As such, they have loaded up some good deal's on select 20v max kit's.
DEWALT® Launches New Reciprocating Saw with Unique, Compact Configuration for Balance and Control*
TOWSON, Md. (Feb. 7, 2012) – Today, DEWALT announces the launch of its new Reciprocating Saw (DWE357), which features a unique, compact configuration that provides outstanding control and balance compared to traditional reciprocating saw designs, without sacrificing the power that professionals expect. The DWE357 is ideal for general contractors, mechanical contractors, demolition workers, electricians, HVAC professionals, framers, remodelers and other residential and commercial construction professionals who are tasked with completing cutting applications in tight spots, overhead and other challenging workspaces.
“Our new, compact reciprocating saw is designed to provide professionals with improved balance and comfort, allowing them to complete a variety of cutting applications efficiently,†said Ivonne Meza, DEWALT product manager. “The saw’s innovative configuration enables contractors to cut in tight spaces where reciprocating saws can’t typically go, providing versatility on the jobsite.â€
The reciprocating saw weighs just 6.8 pounds and is 14.5 inches in length, making it 20 percent shorter than other traditional corded models currently on the market. The compact size allows users to make strong, fast cuts in small spaces such as in between rafters and studs, under sinks and in corners.
Despite its small size, the DWE357 features a 10 AMP motor that delivers the power to complete tough applications, with 2,800 strokes per minute (SPMs) and a 1 1/8-inch blade stroke length. The saw is designed to provide balance and control, ultimately helping professionals to work longer and experience less fatigue.
In addition to its compact design, the DWE357 includes several innovative features including a lever-actuated, four-position blade clamp and fixed/pivoting shoe. The four-position blade clamp is unique to DEWALT reciprocating saws and allows users to position the blade in horizontal and vertical positions. The pivoting shoe provides the leverage necessary to complete different applications, making the saw versatile particularly in flush-cutting applications. Additionally, the DWE357 includes a keyless blade change feature that allows users to replace the blade easily and efficiently.
The DWE357 also features an ergonomic handle with a soft overmold for comfort while cutting. The handle helps to minimize discomfort for contractors who use reciprocating saws throughout the workday. Also aiding in comfort, the saw features a variable speed one-finger switch.
The reciprocating saw will be available at home centers and through the independent channel in the second half of 2012. The DWE357 is expected to retail for approximately $129.00, and will come standard with a three-year limited warranty, one-year free service contract and 90-day money-back guarantee.
About DEWALT;
DEWALT® Launches New 12 Volt MAX* Pivot Reciprocating Saw, a Lightweight Solution for Making Quick Cuts in Tight Spaces
TOWSON, Md. (Feb. 7, 2012) – Today, DEWALT announces the launch of the 12 Volt MAX* Lithium Ion Pivot Reciprocating Saw (DCS310S1), an addition to the 12 Volt MAX* system that was launched in September 2010. The saw is ideal for a variety of professionals including remodelers, electricians, cabinet installers, plumbers, HVAC contractors as well as maintenance and repair professionals.
“After logging many hours on the jobsite, speaking with professionals and observing the challenges they face on daily basis, we quickly learned that contractors spend a lot of time maneuvering in tight spaces,†said Sean Templeton, product manager, DEWALT. “When DEWALT designed the new reciprocating saw, we incorporated a pivoting three-position handle with our 12V* MAX battery to give users a compact, versatile and lightweight saw that delivers a fast, clean cut.â€
The new DCS310S1 features an adjustable three-position handle that allows contractors to adapt the saw to complete applications in confined spaces. The pivoting shoe also provides versatility for cutting a variety of materials. The DCS310S1’s keyless lever-action blade clamp allows users to easily change or reverse a blade, providing even greater access to tight spaces or allow for flush cutting.
With a 9/16-inch stroke length, 0-2,700 strokes per minute (RPMs), and a 12 Volt MAX* 1.5 Ah battery, the new pivot reciprocating saw provides the power users need in a lightweight, ergonomic package.
Just like other tools in the DEWALT 12 Volt MAX* line, the new pivot reciprocating saw is equipped with a bright LED light to illuminate dark work areas without shadows, for better visibility.
The DCS310 will be available in April 2012 at Lowe’s and independent distributors. The kit (DCS310S1) will feature one DCS310 reciprocating saw, one 12 Volt MAX* 1.5 Ah Lithium Ion battery pack, one 30-minute charger, one four-inch six TPI wood cutting blade, one four-inch 18 TPI metal cutting blade and a kit bag. The kit is expected to retail for approximately $149.00. The DCS310 will also be offered in a variety of 12 Volt MAX* combo kits, including the DCK212S2 ($199.00), a two tool combo kit featuring the 12 Volt MAX* 3/8†Drill/Driver (DCD710), and the DCK413 ($279.00), a four tool combo kit complete with the 12 Volt MAX* Drill/Driver (DCD710), 12 Volt MAX* 3/8†Impact Wrench (DCF813) and the 12 Volt MAX* LED Work Light (DCL510).
The tool will come with a three-year limited warranty, one-year free service contract and 90-day money-back guarantee, and the battery packs come standard with two-year free service contract.
About DEWALT;
DEWALT is a leading manufacturer of industrial power tools and accessories, including corded and cordless drills, saws, hammers, grinders, routers, planers, plate joiners, sanders, lasers, generators, compressors, nailers, saw blades, metal and masonry drill bits, abrasives, screw driving accessories, and more. DEWALT tools can be found nationally and internationally, wherever tools are sold. With more than 1,000 factory-owned and authorized locations, DEWALT has one of the most extensive service and repair networks in North America. For more information, visit www.dewalt.com or follow DEWALT on Facebook and Twitter.
DEWALT® Launches Two New 20 Volt MAX* Lithium Ion 1/2-Inch High Torque Impact Wrenches for Heavy-Duty Fastening Applications
TOWSON, Md. (Feb. 7, 2012) – Today, DEWALT announces the addition of two new 1/2-inch High Torque Impact Wrenches to its existing 20 Volt MAX* Lithium Ion system. The DCF889L2 impact wrench with detent pin anvil and the DCF889HL2 impact wrench with hog ring anvil are designed for mechanical contractors, plumbers, automotive users, maintenance and repair professionals and remodelers. The DCF889L2 and DCF889HL2 are designed for professionals who demand a tool for difficult fastening applications, such as driving and removing fasteners, nuts and bolts in wood, metal and concrete.
“The DCF889L2 and DCF889HL2 are the best DEWALT impact wrenches yet,†said Phil Lalle, product manager, DEWALT. “Professionals will find that these wrenches deliver the power, durability and control they need to tackle the toughest tasks on the jobsite.â€
The new impact wrenches deliver 300 ft./lbs. of torque to perform a wide range of heavy-duty fastening applications. In addition, the DCF889L2 and DCF889HL feature a variable speed trigger with an electric brake for added control. The units provide 1,650 revolutions per minute (RPM) and 2,600 impacts per minute (IPM) for powerful application speeds. Both models also feature an LED light, providing greater visibility when working in dark, tight spaces.
Another feature contractors will benefit from when using these tools is the heavy-duty impact mechanism that is powerful enough to complete difficult applications without creating reactionary torque or kick back.
In addition, the tools run off of DEWALT’s new 20 Volt MAX* batteries with Fuel Gauge LED indicator lights that allow professionals to see how much charge is left in the battery.
The DCF889HL2 features a hog ring anvil that allows for easy socket change, while the detent pin on the DCF889L2 provides a secure socket grip. For extended durability, the DCF889L2 and DCF889HL2 are equipped with a magnesium gear case and all-metal transmission.
The DCF889L2 and the DCF889HL2 will be available in June 2012 through industrial distributors. The kits (DCF889L2 and DCF889HL2) each include two 20 Volt MAX* Lithium Ion 3.0 Ah Fuel Gauge battery packs, one fast charger and a kit bag. They are expected to retail for approximately $329.00.
The new impact wrenches are also available as bare units (DCF889B and DCF889HB), which are sold without batteries or chargers; they are expected to retail for approximately $169.00 through industrial distributors. The tools will come standard with a three-year limited warranty, one-year free service contract and 90-day money-back guarantee. For more information visit: www.dewalt.com.
About DEWALT;
Summary;
DEWALT launches the 20 Volt MAX* Lithium Ion 1/2-inch High Torque Impact Wrench with Detent Pin (DCF889L2) and the 20 Volt MAX* Lithium Ion 1/2-inch High Torque Impact Wrench with Hog Ring Anvil (DCF889HL2). The DCF889L2 and DCF889HL2 are designed for remodelers, automotive users, mechanical contractors, plumbers, maintenance and repair professionals and remodelers.
Social Content for Publishing
Twitter
Tough fastening applications don’t stand a chance w/@DEWALTtough’s two new high-torque impact wrenches on the 20V MAX* system. http://bit.ly/xZfVIe
Facebook
Tough fastening applications don’t stand a chance with the two new 20V MAX* premium impact wrenches from DEWALT. Check out the impact wrenches and the new line of 20V MAX* tools here: http://bit.ly/xZfVIe
* With respect to the 20V MAX*: Maximum initial battery voltage (measured without a workload) is 20 volts. Nominal voltage is 18.
DEWALT® Launches 20 Volt MAX* Combination Dual Port Fast Charger
TOWSON, Md. (Feb. 7, 2012) – Today, DEWALT announces the launch of its new Combination Dual Port Fast Charger (DCB103). This new charger supports existing stem pack batteries on DEWALT’s 7.2, 9.6, 14.4 and 18 Volt systems, as well as the new 12 Volt MAX* and 20 Volt MAX* systems.
“Knowing that so many contractors rely on our cordless products to earn a living, we are dedicated to continually improving our battery chargers to ensure they meet professionals’ demands,†said John Castelino, senior product manager, DEWALT. “DEWALT’s new Combination Dual Port Fast Charger is a convenient solution for our customers to maintain battery power on the jobsite, whether they’re working with a slide- or tower-style battery pack.â€
With 69 million 18 Volt tower-style battery packs actively being used in the U.S. market, and rapidly growing 12V MAX* and 20V MAX* systems, professionals are in need of a charger to perform efficiently on the jobsite. The new dual charger has the ability to support both tower-and slide-style battery packs simultaneously. By creating one charger that supports multiple batteries, DEWALT is enabling contractors to move quickly from one task to the next with tools that are ready for the job.
The Combination Dual Port Fast Charger will be available in April 2012 anywhere DEWALT products are sold and is expected to retail for $99.00. The charger will have a three-year limited warranty, one-year free service contract and a 90-day money-back guarantee.
About DEWALT;
DEWALT is a leading manufacturer of industrial power tools and accessories, including corded and cordless drills, saws, hammers, grinders, routers, planers, plate joiners, sanders, lasers, generators, compressors, nailers, saw blades, metal and masonry drill bits, abrasives, screw driving accessories and more. DEWALT tools can be found nationally and internationally, wherever tools are sold. With more than 1,000 factory-owned and authorized locations, DEWALT has one of the most extensive service and repair networks in North America. For more information, visit www.dewalt.com or follow DEWALT on Facebook and Twitter.
Summary;
DEWALT’s new Combination Dual Port Fast Charger (DCB103) is compatible with DEWALT batteries including the existing stem packs in 7.2, 9.6, 12, 14.4, 18 volts, and the 12 Volt MAX* and 20 Volt MAX* systems.
Twitter
The new 20V MAX* Dual Port Fast Charger from @DEWALTtough charges your stem and slide packs http://bit.ly/wtfD61 #PowerTools
Facebook
Wouldn’t it make things easier and faster if you had one charger that could handle your DEWALT stem and slide battery packs? Well now that convenience is available, with DEWALT’s new Combination Dual Port Fast Charger that is compatible with both DEWALT battery types.
Also check out their new Duel Port Combination Charger – it charges all of your DEWALT batteries for 20V MAX* stem and slide pack batteries from 7.2 to 20 volts. http://bit.ly/wtfD61
* With respect to the 12V MAX*: Maximum initial battery voltage (measured without a workload) is 12 volts. Nominal voltage is 10.8. With respect to the 20V MAX*: Maximum initial battery voltage (measured without a workload) is 20 volts. Nominal voltage is 18.
12 amp hour XRP 18v battery
in Around The House
That's quite the setup you have there! Do you actually use this setup, or was this just for fun?
