rossi7x
109 -
Posts posted by rossi7x
I have started doing this in my job trailer and was wondering what you were using to mount the rails on. I have bought 1" square tubing from Home Depot and the brackets have a little trouble sitting on that.
Hi Addicted....
I used 'metric' equivalent to 1" square tube (being in the UK) and this seemed to fit really well.. It was even able to cope when I had the rack powder coated.. Using steel (as opposed to Aluminium) means that the corners are slightly rounded, and does not cause an issue..
Here's a shot of my bare steel from and a bracket.. More photo's kicking around if you need..
Hope this helps..
Thanks for the compliments Mr Yellow. I take it you must be looking at photo's sent to you by Dano-UK, or some that have hit the Internet from somewhere else.. Yes they are standard steel wheels from a VW T5
T32 model. They have been banded from 6.5j to 8.5j on the fronts, and 9.5j on the rears, and then powder coated in Audi 'bright' Silver. I am running 225/50/17 tyres which give a little 'Euro look' stretch on the rears. The van is lowered and sits on fully adjustable coil-over suspension...
Checked out your photo's and they look great... My Van is a VW T5, so is much smaller than yours, although I have 19 tough boxes in total in the Van..
The boxes are fairly close to each other, although you can easily lift the side handles to release them. The van is pretty tight on space from the back doors to the bulkhead, so everything is measured to the last MM..
Thats why I have the trestles hanging just inside the curves of the back door, and have my 2.6m Rails (2off) slotted above the Boxes in the Birch Ply channel on the RHS of the Van.
On the LHS there are 3 wooden shelves (screwed to 25mm box section rack) to hold tools and miscellaneous. These too are built in Birch Ply, Dovetailed on the edges and lacquered..
I will post up some more pics at some time, although I believe that Dano-uk has posted you some..
My set up means that I can unload the van, including racking in under 10mins to have a completely empty shell..
I think I may have seen a photo of your set up via an e-mail from one of the UK Marketing guys at Head Office.. Would be great to see if it is the same wagon...
Is this yours....
Yes Mr Yellow...
Standard trestles that are powder coated black, and just signs made up..
Was recommended by another forum member to check out photo's of you Tough system build, but for some reason I can't seem to view them on here.. Any ideas...??
Hi Dan...
Thanks for taking the time at Sandown to come and see the Van.. Between there and Kempton Park (D&M Toolfair) the van was pretty much mobbed and pretty well received..
You probably have more pics of my van than me.. In fact it would be cool to see some others..
I have tried to look at Mr Yellow's photo's on this forum, but I cannot seem to view them. They appear to be blank in the thread, or little blue boxes where (I guess) images should be..
Again, would be great to see his photo's at some time..
I will get some photo's of the rails tomorrow, and post them up..
Hope you enjoyed the rest of the show. If you need anything else (info) regarding the van, just drop me a line as I have lots of build pics..
Cheers
Jules...
The word in the UK is NO..!! ... something about potential infringement of International patents that run out Jan 2013.. then not too long after that for potential release.. javascript:void(0);
Actually got one of these myself...
Sits really well in my Tough Box Van racking system I built...javascript:void(0);
And general shelving
Not exactly 'showing off' my Dewalt tool collection, but I thought I'd show how I've racked my Van to get them to the Job-site. I have basically welded a 1" x 1" box section steel framework together and bolted on the van in such a way that it is removable.
The Tough System boxes fix to the same arms as the trolley system, so each box is removable independently.
During build...
After some ply detailing and racking to maximise storage around the Tough System
And the other side of the Van with general 'Ply' shelving
Enjoy..
- 4
Will 20 Volt lithium battery work on 18 volt XRP tool?
in Dewalt
As far I am aware, the 20v XR Li-ion kits are decided by the U.S. head-office.. In Europe they are still called 18v (as opposed to 20v max in the U.S.).. Originally the UK kits also came with a re-cip saw, and this was based upon the fact that cordless re-cip saws are a massive seller in the US, so they feel that the rest of the world should follow suit..
In fact, it is proven that a Jig-saw is a much better seller in Europe than a re-cip. Hence the fact that we now have a second 5 kit with a jig saw(as opposed to the re-cip) and also a 6 kit which adds the cordless grinder..
As another post say, buy a 5 kit and then add a bare unit jig-saw to suit..
