1,063 -
Posts posted by jeffmcmillan
Seems like every year is the best yet so next year should be even better
2 hours ago, Hugh Jass said:
I think it comes down to too slow of an RPM personally, under bind the tool has time to become the reciprocating portion of the action instead of the blade which remains largely stationary, starting a unstoppable chain reaction, turning you into a puddle of the previous man you knew yourself to be.
What could help overall?
Orbital action.
AVT.
Faster RPM.
More powerful motor.
Paste of wood glue combined with Unicorn horn dust drawn into circles of demonic protection on the inside of the motor housing.
That should do it.
I actually dislike orbital. With proper pressure and proper tooth count you can cut faster in demo and putting pressure on it in orbital means more vibration plus a worse off blade if you hit metal. Might be I'm doing something wrong or just different though.
4 hours ago, AnonymousJoe said:
Well got my drill back today. They replaced the armature. I'm not sure what that is but hopefully it's fixed and I'll try it out at work tomorrow. I will say this tho about the new chuck they put on it-zero wobble! I even put an old hammer drill bit in it just to see and it spins as true as I've ever seen so I'm really happy to see that! The old wobble really used to bug me.
So can anyone tell me what the armature is?
The armature is the motor windings (ie. the thing that was smoking) so I'd be impressed if that doesn't fix it.
3 hours ago, pancing said:
Heh, My fiance watched me with bated breath and a massive grin on her face as I put the blender head in my m18 fuel to whip some egg whites for a cake... The whole time I was tightening the chuck I was wondering why she was so interested all of a sudden when I use my tools. She laughed for a good 10 minutes when I pulled the trigger and 6 eggwhites ended up all over me and everything within 10 feet.
Problem is eggbeater "bits" work in pairs. A few minutes with pliers and you can make them work great individually though. You can apply power tools and fluid dynamics to cooking simultaneously!
If by kit you mean drill and impact, Makita's new subcompact brushless kit is $230, and I don't think you can do bettery for the price point. After that I think the good ones go up to around $200 bare tool which isn't exactly what you want.
I love makita's impacts, but you definitely pay a premium for them.
Great job. I can't even remember the last time mine looked that clean. Somehow hasn't needed repairs yet though so fingers crossed.
1 hour ago, KnarlyCarl said:
Two pack of Avanti 10" 60 tooth blades for $24.97
Sounds like ok blades, maybe use them with older or dirty lumber, throwaway price, to be expected being that cheap...
The problem is 60t is a lot of teeth for rough cuts. Thin ply is the only thing I could find they were decent for.
They've started marking down a ton of stuff online in the last couple days but nothing that great. Then there's this wacky thing I ran into that I've never seen before...
http://www.homedepot.com/p/Makita-Drywall-Nose-Adaptor-for-Impact-Drivers-194633-2/205182378
Homeowners dread spending a fortune on batteries later to keep their old tools working. Having $10 batteries on the shelf will help a lot of kits sell for Christmas and they can normalize the price later.
5 hours ago, HiltiWpg said:
Buy them up, strip out the cells and sell them for $3-$5 each on eBay!
Almost like the playstation clusters.
I think the price for 1500mah cells is pretty low now though.
12 hours ago, HiltiWpg said:
This has been out for awhile already.
http://www.techtoolsupply.com/QBit-Cut-In-Saw-for-Multi-Tools-Single-Gang-p/lss-sqs1000-s.htm
I think the op one moves each blade independently so they're always cutting linearly whereas that one would be moving the blades at a 45 degree angle near the corners. It might just not matter though.
They must have gone to the extreme of high energy low power cells. Power tools are really on the opposite end with high power lower energy capacity cells
Any chance it's the same people who made this?
The collet nut is stripped? Replacing it would be a lot cheaper. I've heard the quick release has some bugs.
9 hours ago, dwain said:
It should smash 1/4" ply. Also, in Australia and elsewhere it is specified as a 140mm blade, which is actually 5.5". I wonder why it's called 5-3/8"?
Sent from my iPhone using Tapatalk5-3/8 is a standard blade size just really uncommon
11 hours ago, CATERPILLAR said:
Thanks man i will check it out but first i got to buy a 4.5 grinder i have a 4 inch,5inch9inch but not a 4.5 lol will probably get a makita:) have a good one #tiacrew
My Lowes has the lenox blades in a lot of sizes, at least 4 and 5 inch. Maybe 9 inch too.
17 minutes ago, joemontague said:
Ebay or atlas machinery out of Canada I ordered a white one off ebay and got my green one from atlas and I got a blue from construction fasteners out of canda as you can tell I really like this impact
Great way to keep it from getting stolen. People will assume it's just the cheap homeowner line and don't bother.
I think part of the differences is tesla moving to 20700 so in addition to the 30% volume increase the cells themselves have a higher performance.
The Bosch 6.0 batteries would often have a shorter runtime than 5.0 because at high draw the battery wasted more energy and heated up.
1 hour ago, dwain said:
which shouldn't be a problem because there are three rows of cells to provide current.
I am (as noted above) also concerned about their 6Ah batteries being a compromise. Having said that the M12 6ah batteries are awesome.
What about the compact 3ah? That seems really questionable.
4 hours ago, KnarlyCarl said:
I think if I were on the Makita platform I would have this set and the full size set and forget the 12v tools. Keep it down to just one battery
Not to mention they're black. It's a shame they just updated the entire 12V line.
5 hours ago, ChrisK said:They have the new brushless micro 18v tools for Makita at my local HD. But....$229....yeeeesh. That's a lot of money for the set. Feel great in the hand though and oh so tiny.
$229 seems reasonable. You can't expect the price tag to be as small as the tools. In fact looking at home depot it's on the lower end of entry level brushed kit prices despite being top of the line brushless.
35 minutes ago, JimboS1ice said:
Yea the 20700s are awesome, but doubt well see dewalt introduce that tech in their 20v battery
From the pictures it looks like they use them in the 20V 6.0
1 hour ago, AnonymousJoe said:Since u guys brought up flexvolt I have another question. I read somewhere about a tool having a noticeable power increase going from a compact battery to a higher capacity 10 cell battery. Now would u see a noticeable power increase using a flexvolt battery because it has 15 cells vs a 4 or 5 ah battery with 10 cells?
That depends on if the tools is capable of using the extra power, and before you ask I have no idea which ones. It will also take longer to overheat in heavy use for any tool.
First off, it's going to be a bit bigger and heavier, not flexvolt big but a little, hopefully to avoid the problems Bosch had.
Also the 6ah batteries tend to have a significant premium over the other batteries because of the expensive cells they use. It's almost 100% increase in price for up to a 20% increase in runtime. That's not worth it in my book. I'm happy to seem them push the 5ah prices down though.
15 hours ago, JMG said:
Riddle me this: When the tool is switched off, does it release the firing cylinder from its ready to fire state?
The firing mechanism is a highly compressed nitrogen cylinder. There are much worse things that are probably going wrong at that point.
RED INFINITE BATTERY
in Milwaukee
I didn't even notice the wireless charging on there. Great attention to detail nalu. Figures I'm the one who needs the joke explained XP
Strangest thing about the AC/DC thing is that some long transmission lines use DC now because inversion has gotten more efficient and there's no capacitive loss.
