208 -
1
Posts posted by phffter
2 hours ago, KnarlyCarl said:
If the pros are correct, that's what I see them doing, must be for a good waterproofing seal behind the tile
we covered this topic at work. two carpenters, 1 painter, 1 plumber, 4 engineers. a couple of 'em own rentals.
consensus was 'it 'll be fine'. durock is porous. mudding those seams wont add much, if anything.
+ both baths i demo'ed in this house, 1 was green board, the other plaster, with no barrier, the walls were not damaged. same with the 2 baths in a previous house.
+ i'm leaving this overtaxed state in 3 years. it'll be fine.
+ i aint a pro.
- 2
9 hours ago, rrich1 said:
Colors look good. Any reason why you didnt tape the seams and mortar them before tiling?
any reason to as in why do it?
been hashing out in my mind the next step.
chest is still sore from vfd upgrade.
built a visqueen cocoon around the wetsaw in the basement to keep the mess down, and started with the tile.
been awake many a night figuring where the lines all go, to even all them out. aint got the vanity, that's the starting point.
started at the far end of the tub, used my laser level for a line, worked my way around. the first course, up, around, and down, took too long. whole tiles, go up as fast as possum shit. stopped when i ran out of mixed mortar, and my knees were complaining.
hole sawed the tile for the tub valve, cut a bunch of little guy trim pieces.
whaddya think of her color choices?
there will be a second accent line, above the tile over the 1st accent, all the way around.
midwest university
enroll, watch (3) 2 minute videos, complete a 'test' after each, get a freebie! tshirt, scribe, awl, or - i forget the 4th item.
i got a tshirt
my sons are 27 and 24. yours are still young. mine should know better.
lines................ depends. i spent alot of time on both baths with the soffits, so i would have an unbroken line and uncut tiles, from floor to ceiling, along the outside edge of the tub, front and back. upstairs i was dead nutz on. this one, im a little out in the back. dont know how, everything is square. i dont think it will that that noticeable.
- 2
can not 'paint' a straight line in paint if my life depended on it
wow! building the vanity. very nice. you win!
need a seperate build thread!
i wish i had the time to build one myself, i dont.
plus the 2 animals i call sons will phuck it up (unintentionally) in short order
just pharting around, had my 'device' replaced thursday.
resanding, recoating over the past few days. the premixed mud is taking forever to dry. started looking for the (i know i have 2 partial bags) of '20' compound. can't find, and i aint gonna buy a 3rd bag to misplace. found a small amount of '5' compound. turns out it's more like 5 HOURS!. got it primered, and found alot of imperfection. flat paint hides alot.
i like the drawings. good deal!
dont know how to do them, that a special 'program'?
big box diy menards carries masterforce, which are rebranded USA armstrong.
i set up my (2) impact boxes and my socket drawer with them.
going to cut the accent tile down into 3 tile widths. and have a double band. seperated by 1 course of grey.
i dumped out a large handful, as seen in the background, in front of the box. i easily found 8 screws that had too much 'goop' on them.i attempted to clear out the stuff, was able to do so on 4. the others got tossed.
and, the wall tile with the accent. the mrs picked them out.
im color blind, she assures me they'll look great.
- 2
and i did find time to buy some new tools. a dewalt die grinder from amazon, and a knipex branded jerman made 5 piece screw extractor set from tool topia.
i aint forgot about the job. been catching up on battening down the hatches for the rapidly approaching winter, in addition to still working o/t.
leaf blower bought. neighbors leaves blown (i shoulda blew them back into his yard where they came from), coupla lights replaced in carage. reused electric roof heaters, ran thru gutters and downspouts. (originally some was on roof, just had roof redone). gazebo fabric and screens stowed. coronet stored. shit in shed and carage moved around for the seasons.
still gotta check snow blower!
anyways. floor done. drywall/dur rock done. electric done. medicine cabinet hung, and rehung to make placement more better.
the exposed raw corners taped and mudded, 2nd coat. walla walla marked as to where the accent tile lines will go.
old door jamb still in.
you guys know what it looks like, so no pics.
finishing that window still seems like a pia. i hope i can cut 3/4'' wide pieces of 'fill' tile.
used a 'new' screw for the cement board. wide countersunk #2 square drive head. they seem ok, except whatever process the chinese use to coat them, seems to fill the drive hole on every second screw i pick up. especially when trying to sink a screw while holding a panel, a third hand would be really nice. wound up using a drywall screw for the 1st couple of fasteners per panel. these i will take a pic of, and i will not recommend them for their intended use. .
these
69 1/2 a12 roadrunner
sounds like you have made progress. and seems your room has way more room than mine. bigger is better
schrock makes nice cabinets. ours is a schrock. 4 weeks away. top is 4 weeks away
i can make the vanity, just aint got the time, or, with the coming winter, the room to run a table saw. (coronet is taking up a bay)
grouted floor, wiped glaze 2x.
crapper gets reinstalled tomorrow. may reinstall old vanity/sink/faucet temporarily.
i guess, the next thing to tackle would be ripping out the door frame, and fit new jamb boards in. exist trim is pine, pine door latch area busted. installing oak jams and a 6 panel door.. need to get the oak trim up, before i can tile (up to them). cant tile walls till i get vanity
i might be able to tile tub area.
still have 2 partial sheets of greenboard to hang also
you guys may have noticed that i'm NOT a fan of cordless tools. i usually wind up stringing out a cord to finish a job.
and the co$t of replacement batteries? are you kidding me?
anyways, another nail in that coffin - hopefully not mine.
the past week, was notified by my cardiologist wanting an 'in office' meeting.
was told that the generation of battery powered ICD in my chest, that was replaced last year, is on a recall list.
icd's battery life is 6-8 years. im dependent, so 6 is it.
device subject to sudden rapid battery depletion. replacement is scheduled soon.
- 4
made large strides today.
cut/installed all the dur rock in tub stall.
installed bottom course of green board on both walls.
yanked the crapper, installed the floor tile.
got half down, and noticed it was the wrong color.
awaiting mortar to set up, so i can close that window, which i see will be a 'of' to finish.
btw, used a new bosch 7'' wet saw blade, bought at cripe, in my hf beam wet saw.
blade was exceptional. the hf ones i originally used, chipped tiles.
pics to come later.
also................ thought that by tearing out the plaster and installing 1/2 rock, i could squeeze a bigger vanity (24'') in.
nope. still too tight. a 21 would have kinda worked, but very special order.
special ordered 18'' vanity and top. you do not want to know the $
is that unit p/n 2530-20? i acquired one, not impressed. bogs on 1/4'' plywood, tripping the internal protector. new unit, new blade. i forgot what i traded for it. if i bought it, it would have been returned.
plumbing done.
thanks carl, used your suggestion, silicone and dope. and vacuum grease on the rubber.
walls shimmed out as needed, eliminated two jointed corners by building out the entire non plumbing wall. added blocking to support wall hangers. added blocking, for where im going to transition between cement board and greenboard, to hide that 'seam' under tile. need to finish hanging plastic in the shower/tub area, and then time to rock.
- 2
5 minutes ago, rrich1 said:
Did you use any plumbers putty above the tub to the drain? My kit didn't say to use it but it leaks without it. Try that first and I bet you will be fine. Did you buy the Lyons linear tub? That was the one we got. Had to get an6"extension tube as well.
used whatever drain assembly menards had that fit. plumbers putty under the drain, inside the tub. seems the rubber gasket, under the tub is leaking. i put it in dry, going to put some vacuum grease on it tomorrow.
bought the tub from menards also.i forget which model,
i forgot all about this.
they're buried somewhere. got the titans.
12 hours ago, KnarlyCarl said:
You would need access behind the tub yes? To put the foam under once the tub is set?
plop it done after squirting the foam. have the tub nearly in position, up on blocks, use 1/4 poly tubing to extend the nozzle. the 6'' supplied nozzle aint long enuff.
10 hours at work today, and,
drain and water done. have to redo tub drain, chinese supplied rubber gasket leaks.
mebbe a pic tomorrow
world series on
Main Bath Gut
in Around The House
well, to prove im not a complete hack, broke down and bought a tub of spreadable membrane. the little window ledge has been bothering me, especially at 3 in the morning when im trying to sleep. painted the 3/4'' ledge around the window, and whatever i didnt tile on the wall around the window
now, that i have the goo, i shoulda spread it all over the shower stall.
probably will have a 7/8 full tub of hardeded crap next time i open it.
