n8n82250 Posted November 1, 2016 Report Share Posted November 1, 2016 So my dremel 3000 shaft is starting to get stripped and I cannot take out the sanding drum. I'm looking at the dremel 4200, does anyone have an idea on how well they work and would anyone recommend me a better corded rotary tools if so, I need your help.Sent from my XT1080 using Tapatalk Quote Link to comment Share on other sites More sharing options...
jeffmcmillan Posted November 1, 2016 Report Share Posted November 1, 2016 The collet nut is stripped? Replacing it would be a lot cheaper. I've heard the quick release has some bugs. Quote Link to comment Share on other sites More sharing options...
n8n82250 Posted November 2, 2016 Author Report Share Posted November 2, 2016 The collet nut is stripped? Replacing it would be a lot cheaper. I've heard the quick release has some bugs.The shaft lock is slipping when I press it down and try to unscrew the collet nut.Sent from my XT1080 using Tapatalk Quote Link to comment Share on other sites More sharing options...
KnarlyCarl Posted November 3, 2016 Report Share Posted November 3, 2016 On 11/1/2016 at 8:00 PM, n8n82250 said: The shaft lock is slipping when I press it down and try to unscrew the collet nut. Sent from my XT1080 using Tapatalk Is there no other way to hold the shaft from spinning such as a pair of pliers? Quote Link to comment Share on other sites More sharing options...
JimboS1ice Posted November 3, 2016 Report Share Posted November 3, 2016 No expeierence on the newer dremel I still have a 400xpr but don't use it much, it needs brushes, I pretty much replaced it with the cordless Milwaukee rotarySent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
CATERPILLAR Posted November 7, 2016 Report Share Posted November 7, 2016 On 11/1/2016 at 3:27 PM, n8n82250 said: So my dremel 3000 shaft is starting to get stripped and I cannot take out the sanding drum. I'm looking at the dremel 4200, does anyone have an idea on how well they work and would anyone recommend me a better corded rotary tools if so, I need your help. Sent from my XT1080 using Tapatalk take the dremel apart and get a pair of pilers and grip it on the shaft coming from the motor and turn the nut off had the same probelm with my dremel 3000 have a good one if you have anymore tool repair questions just pm me Quote Link to comment Share on other sites More sharing options...
