Bohunter27 Posted May 8, 2021 Report Share Posted May 8, 2021 Just bought a new 20v Dewalt brushless kit with circular saw etc., the blade does not cut where the line is on the saw guide/foot. The blade is one full width outside of the guide line. Has anyone else had this problem and is there a fix for this. It is a brand new saw. Quote Link to comment Share on other sites More sharing options...
FramerJoe Posted May 13, 2021 Report Share Posted May 13, 2021 Why are you using a base to make a cut? You should be using your eye on the line either outside the saw or through the “ window” of the body of the saw, if your just making rough cuts then the guide is fine Quote Link to comment Share on other sites More sharing options...
