Pancake Compressor Question
eric
  • 7 months later...
check for leaks in the hoses or the couplers. also check to make sure that the pressure switch is not leaking. direct drive compressors usually do take a lot longer to load, and re-load to begin with, if "forever" is really only about 4-5 minutes then thats normal. otherwise i would say the pressure switch is bad
    RHunt
    RHunt
