RickyMcGrath Posted May 19, 2015 Report Share Posted May 19, 2015 If you plan on purchasing the adapter for the router to use the guide rail (DWS5021) I suggest only using it with the DW625 as the adapter doesn't allow other routers to extend past the guide rail causing alignment issues when making dados. The DW625 fits perfectly with the guide rail, flat on your stock making perfect dados. Quote Link to comment Share on other sites More sharing options...
Kenneth Denmark Posted May 19, 2015 Report Share Posted May 19, 2015 ..? I have used it with other routers with out any problems http://s7g3.scene7.com/is/image/ae235?$p$&layer=0&size=281,281&layer=1&size=281,281&src=ae235/53211_P Quote Link to comment Share on other sites More sharing options...
RickyMcGrath Posted May 19, 2015 Author Report Share Posted May 19, 2015 I could not get it to work on the DW618. On either base. Especially the plunge base. Quote Link to comment Share on other sites More sharing options...
Kenneth Denmark Posted May 19, 2015 Report Share Posted May 19, 2015 I will test it later.. I don't have the DW618 but the d26204.. I be back! Quote Link to comment Share on other sites More sharing options...
Kenneth Denmark Posted May 19, 2015 Report Share Posted May 19, 2015 Only the plunge base.. On the DW618 that true..! But you can use it on all Dewalt routers.. 1 Quote Link to comment Share on other sites More sharing options...
