2,125 -
11
Posts posted by RickyMcGrath
(Place holder for updates)
The sink is set! Need to hook up the disposal and reset the face frame.
All cut and polished to 400 grid. I had a lot of extra work undercutting the bullnose and the decking so I didn't get finished with the polishing. I'm going to hit the newly cut edge with some densifier/hardener tomorrow then finish polishing up to 10,000 grit.
Bought my wife a new Kohler apron front sink for Christmas and I was tasked with doing the swap out. It's going to be an interesting task.
Master b... never mind
Sent from my iPhone using Tapatalk Pro
Karate master -
How many miles were on that engine when you put in the Amsoil? I ask because switching to Amsoil can sometimes actually clean out any deposits and/or metals. It could also be that the rings are worn and that engine likes the thicker oil. Amsoil tends to run a bit thinner at operating temperature while meeting proper weight and viscosity.
Roughly 75,000 miles. On a diesel, it wasn't even broken in yet. Many 6.0L, 6.4L and 6.7L powerstroke owners have reported similar results on another forum that I'm a member of. Amsoil had such poor oil analysis numbers we began to call it "scamsoil" -
I notice the same problem here in the Pacific NW. A large amount of people no longer change their own oil or dont change it period. They all take their cars to dealers or shops and pay anywhere from $65 to $100 for an oil change using "quality synthetics". When they do change their oil, its being done every 5,000 miles which is outrageous.
I do my own oil changes on all the vehicles in my family and in-laws. I just store the used oil in a coulple 5gallon buckets and when full, take them to O'Reillys down the street. Free disposal. I use Amsoil in all the vehicles which saves a lot of time and money, both on oil changes and maintenance. I use their Signature Series which is a 25,000/1 year oil. Costs about $85 once a year, which includes filter. More for larger engines.
I'm not sold on Amsoil. I put it in my 6.4 powerstroke once, ran an oil analysis at 5,000 miles and the wear numbers were double and triple what they are with Rotella T-6. -
I haven't changed my own oil in about 10 years. It's just such a hassle to dispose of the oil. It is a shameful waste of money to pay someone else to do your oil. Such an easy job. Any then you know it is done right. Oh well.
It's pretty easy to dispose of oil for me. Every autoparts store including Walmart will take it for free. I recently discovered that waste management has a special service called AtYourDoor where they will pickup automotive fluids free of charge. It's a lengthy process to schedule it out, but I plan accordingly. I have a pickup scheduled for Jan 11 right now for all my fluids from my recent PM.- 1
I absolutely love my EGO 21" SP mower. I started off by picking up the 20" on clearance this summer and ended up selling it within 45 days and going with the 21" SP. I count be happier with it and I have no complaints whatsoever. I have a thick St Augustine lawn and it worked great on that. I planted Rye for the winter and it works amazingly well on the thinner rye grass. That's both end of the spectrum when it comes to grass types. I have roughly 5500SF of turf and I can EASILY mow everything twice, maybe 3 times if I don't use the SP.
My December maintenance repair I've performed on my own truck:
Oil & filter change
Fuel filters
Replace Body mount bushings
Replace shocks
Replace steering stabilizers
Coolant flush
Rear dif fluid change
Front dif fluid change.
Steering stabilizer change
Fuel cooler maintenance.- 1
So I forget where I read/heard this but is it true? Is Dewalt completely converting to the 20V/60V and no longer producing the smaller single voltage pack in anything above 5ah?
I don't see why they would make an exclusively 20v pack with more than 5.0ah. It's just double production. -
I have this set. Its a fantastic set for small electronics, phones, tablets, etc. it was the only set I found that had the torx for a kindle.
http://low.es/2cRzrvl -
They really are great as long as you're not trying to get one by on them. Took my 4.0 battery in this morning that wouldn't charge. They swapped it out for a 5.0 because that's all they had in stock.
$300 is 30,000 pennies. I think I'll take one of everything!
- 8
I didn't even read the whole thing and I can tell you it's a scam. I often get bored and replay to these scammers and waste their time and resources. They send forged checks from out of state for more than the item asking you to send the extra money via MoneyGram to the "freight company" for pickup of said item. SCAM SCAM SCAM.
This is called the "Workshop Rack." I'm wondering if they're will be a separate mobile solution in the future.
Currently with the $25 off holiday special, purchasing 9 pair of the Dewalt DWST08212 brackets in a single order from CPO brings the price to approx. $12.22 per pair. Ordering 7 units sets the price at approx. $12.41 per pair. They seem to be out of stock on the rack systems at the moment. Outside of the convenience, I am thinking that building my own mounting rail sets might be the way to go.
Yes, it is a disappointment in quality. If you really break it down, these can still be great units for light to mid weight tools and accessories. Let's look at the weigh capacities.... are the 176 lb brackets overkill? How much can you realistically get into a Tough Box and still comfortably lift the box up and put it into the brackets? These less expensive brackets, based solely on math, should be rated up to 88lbs. So, in the most aggressive situation, i.e.; trailer, you should be able to put 50-60 lbs in the boxes no problem and the jolting around in the trailer will keep it under 88lbs of gravitational force.
Let's say you do have a box or two that you absolutely need to put more than the 88lbs, it will most likely be an XL box and surely that box will be either set on the ground or the deck of your trailer.
In summary; we had high expectations because those that use the system already, know how sturdy and heavy duty the brackets were and we didn't consider DeWalt re-engineering the brackets for another part of the same system. You have to ask, are the 176 lb brackets really necessary for YOUR situation?- 2
All purchased for only 2 pennies
Thought you may get a kick out of this.
- 2
I have a 2010 F250 King Ranch 6.4 as my personal truck and a 2016 F250 as my work truck.
- 2
What's the weight limit? Can't over load them bad boys now
440 lbs for the system. Come with 5 pair of brackets so 88 lbs per pair. The old brackets are rated at 176 lbs per pair. Exactly half of the rated capacity. -
I know right? ...should be using zip ties so when you fireman come they will be melted away....
That's classic!
Undermount stainless sink to undermount apron front...
in Around The House
I'm not too concerned about it. Cutting, shaping and polishing the granite is what makes me nervous.
