maxwonga Posted June 16, 2020 Report Share Posted June 16, 2020 i have a makita dhr242 18 volt sds drill which stopped working properly. With fully charged battery, the chuck hesitates, sort of jutters a couple of mm. I see quite a few for sale spares or repair with the same problem, my question is had anyone repaired same drill? A switch is reasonable cheap but a stator is around £90 as the drills are now only about £150 not worth spending too much to repair If this problem happens a lot, is it worth buying a new one of the same model? Many thanks Quote Link to comment Share on other sites More sharing options...
Eric - TIA Posted June 16, 2020 Report Share Posted June 16, 2020 We had one but gave it to a local contractor. Not sure if it was the same model number but it looks the same. So far no issues with his Quote Link to comment Share on other sites More sharing options...
