T922 string trimmer adaptor
346
I have the 922 string trimmer and I want to do some very light brush cutting with it for research ......I assume its left hand threads? and that the standard adaptor kits that you can get on eBay will work? I assume the sizing is normal????
I would assume the same but with so much coming out of China, it's hard to tell how they will fit together and if it would work.  I would assume as long as it says it's made for that model, you should be good.  If not, you can probably return it.
    Lee R.
    Lee R.
