chadlanthier Posted December 2, 2014 Report Share Posted December 2, 2014 So just wondering, I did major oops and left a paint can on my bandsaw table. The paint did not leak or anything, I just left a large ring on the table,like a water mark. Just wondering what's the best way to fix this, and also should I be using some sort of oil on the table. Quote Link to comment Share on other sites More sharing options...
comp56 Posted December 2, 2014 Report Share Posted December 2, 2014 lets see a pic.... Quote Link to comment Share on other sites More sharing options...
madman_us Posted December 2, 2014 Report Share Posted December 2, 2014 WD-401000 and/or 2000 grit wet sand paper,wax remover ( to clean the surface from the WD-40)cabinet makers wax - to seal the surface or you can also use vinegar and 500 grit paper ( I read that but not sure how it works out ) Quote Link to comment Share on other sites More sharing options...
chadlanthier Posted December 3, 2014 Author Report Share Posted December 3, 2014 Thanks guys I'll try that. When I get a chance, I'll add a photo Quote Link to comment Share on other sites More sharing options...
chadlanthier Posted December 4, 2014 Author Report Share Posted December 4, 2014 I know it doesn't look like much, but it drivese nuts. Quote Link to comment Share on other sites More sharing options...
madman_us Posted December 6, 2014 Report Share Posted December 6, 2014 That doesn't look to bad. Its not hard to clean it man Quote Link to comment Share on other sites More sharing options...
chadlanthier Posted December 8, 2014 Author Report Share Posted December 8, 2014 Yeah I already hit with some sandpaper. That's the last little bit just does not want to come up. Quote Link to comment Share on other sites More sharing options...
Duns221 Posted December 24, 2014 Report Share Posted December 24, 2014 try gasoline, or if you have some kerosene they both work but i would take your saw outside before you try Quote Link to comment Share on other sites More sharing options...
