Kenneth Denmark Posted June 3, 2015 Report Share Posted June 3, 2015 Normally when I use my tablesaw indoor and outdoor I have vacuum connected but only with hose on the table.. Do you guys use vacuum on the blade protection as well? Quote Link to comment Share on other sites More sharing options...
ChrisK Posted June 3, 2015 Report Share Posted June 3, 2015 I run my Midi on my DW 745. Quote Link to comment Share on other sites More sharing options...
Kenneth Denmark Posted June 3, 2015 Author Report Share Posted June 3, 2015 I run my Midi on my DW 745.But do have hose on top and on the table? Quote Link to comment Share on other sites More sharing options...
PeteW Posted June 3, 2015 Report Share Posted June 3, 2015 i dont. only time i would use it is is if i am inside a finished house and i can't make my cuts outside. Quote Link to comment Share on other sites More sharing options...
Trim guy Posted June 3, 2015 Report Share Posted June 3, 2015 I use a Bosch table saw and I try to have the vacuum hose up to the dust port for every cut. Inside/outside/ or in the garage. Quote Link to comment Share on other sites More sharing options...
RickyMcGrath Posted June 6, 2015 Report Share Posted June 6, 2015 I never have the blade guard on as I tend to use a cross cut sled. Just the rear vac port. Quote Link to comment Share on other sites More sharing options...
Alan m Posted June 6, 2015 Report Share Posted June 6, 2015 I run the 50mm short festool boom arm hose into a y on the dc port on my dw745 . then a hose up to the guardI only run both if it is a finished house.the dw745 is very good at throwing the dust out the port . if im on a site or in a shed where dust isn't a problem I run the saw with no dust collector but use the 50mm pipe into a bucket. I forgot to turn on the dc one time and filled the pipe up Quote Link to comment Share on other sites More sharing options...
