re battery on Hand Vacuum One+ Evercharge P714K
Jay_OZ
According to the specs the battery is a P102 which is described is having 20% more run-time than a P100 (Ni-Cad) and 45% lighter.
I believe this is the same description used when the P102 was first released in ?2012? so it's a P102 with no runtime/size improvements?
Is this really correct?
Another thing to consider is that this vacuum is designed to be a dust-buster type, small mess cleanup tool that lives in the charger.  You're supposed to take it off of the charger, spend 2-3m cleaning up a particular mess and then stick it back into the charger to top it off again.  The P102 that it comes with is more than adequate for this usage scenario.
