Makita sp6000 plunge saw
Chappie32
Is there any visible arcing? I find it's usually bad brushes that cause a loss of power at first glance. Brushes are cheap, start there.
If that doesn't fix it, you'll have to take it apart presuming it's out of warranty - if it's still covered just send it back to Makita.
If the armature is burned out you'll get smoke, barely enough power to cut anything if not a complete failure to turn after trying for a while. A multimeter will show open circuit across all windings. Check online for common values of resistance, if any are well out of range +- 2-3 counts you have a bad winding.
Check the commutator surface. Does it show signs of burning, is it pitted? Is it out of balance or no longer perfectly aligned face to face?
    tharunjohar46
    tharunjohar46
