1,479 -
10
Posts posted by Justin Hernandez
30 minutes ago, JimboS1ice said:
Apparently nobody listen I would have stuck my damn finger in for the saw ha ha
Sent from my iPad using TapatalkIts only a finger it will grow back!!
Saw this on Facebook since I don't Instagram..lol Awesome!!!!
Super secret DeWalt tool demo site where the tools use the humans as tools
- 2
I like my yellow tools, but an all yellow case might be a little much.lol
- 2
2 hours ago, Atlas2000 said:
Just curious, had the seals failed or just no seals to begin with?
The gasket was there and water tight if you think about it. The water didn't come out so the gasket is good but most likely the water came in from the top and the top part of the gasket is bad. It was full to the top I loosened the one screw and all hell broke loose. The rusty water got all over me and my tools, I wish I would have taken a picture inside the light because the bulb was floating around in the soup..lol Rite after I took that picture I got tried of waiting for it to drain and took both screws out. Huge mistake..lol
17 hours ago, NicolasRamos said:
Goddamn Justin! Had to recently replace a bunch of gfci' and wp boxes on a retaining wall of a flower bed. Landscaping guys kept adding soil and mulch over time, and burying the damn things, corroded the hell out of them.
Sent from my iPhone using Tapatalk ProYea doing electrical work outside sucks, by the time your done you have rewired put new boxes and fixtures in. Here in Florida its really bad with the high humidity and rainy season, nothing lasts outside.
3 hours ago, KnarlyCarl said:Wow good finds, that's crazy.... You sure that water is not for cooling the light? ?
Its the opposite actually how do you think hot water is made?? You use a water filled 175 watt metal halide lamp and ballast with a recirculating pump. Best tankless on the market!!!
- 2
So people always say water and electricity don't mix but I always find the two together. Any outlet, box or fixture outside is going to have some water in it eventually. Lighting fixtures are always the first to go they fill up with water no matter where there mounted at. I made the rite call on this one, it was obvious that the one fixture just needed a new lamp (arc tube was black) and the other I recommend to replace since it looked like it got water inside at one point. Its hard to troubleshoot something from the ground so I convince the owner to just replace both fixtures. To be honest I don't like LED fixtures there expensive and the only benefit is lower energy cost. They are going to cost more to maintain and when the driver fails your just gonna have to buy another fixture. But some people just want them so whatever. The one fixture was full to the top with water, two gallons of nasty smelly rusty water. It got everywhere on my tools, boots, lift and all over the side of the building. The lamp was broken off the socket and the glass was floating inside. You can see in the last picture in the middle on the parking lot the nasty rust puddle. Breaker wasn't tripped and drawing over 3 amps. I guess the ballast was destroyed by water and it was just the other light drawing power which didn't work either it had a bad lamp. Replace fixtures and timer which had a bad timer motor. That one light was really close to that 400 amp three phase weather head it would have been safer to use an insulated bucket truck. I put a rubber mat on the neutral wire since it was so close to the lift basket, you can never be to safe. It was a little windy that day which made things worst by having the lift bounce around. There is also a picture of a GFCI that I found last month that water got to I threw that in here too. I went to troubleshoot it and the whole thing just fell out in my hand. The whole cover was full of smoke too. I have more pictures to post about water and electricity so stay tuned!!
- 3
21 hours ago, KnarlyCarl said:
Haha, this is awesome!!! Poor A.O Smith. You have to stand on the heater to shut the water off..lol All that weight just hanging on those sharkbites, they should have put a screw in it so it doesn't pop off. Just pull on the romex like a pull chain to shut the power off
Yup if you can just send that to me that would be great..lol
That's it I quit!!
32 minutes ago, RickyMcGrath said:
I have a 2010 F250 King Ranch 6.4 as my personal truck and a 2016 F250 as my work truck.
All purchased for only 2 pennies
- 3
I used it today for the first time in its new home, the attic..lol Don't know if I could give it five stars but its nice it could be brighter and the hinge is loose. But I am super picky when it comes to tools, so my review probably won't matter. Its hard to see in this picture but the insulation is charred as well as the insulation on those white 14-2 romex's. The new yellow 12-2 is were the fire started and melted that wire, which I had to cut out the brunt section and splice it. An A/c contractor started a fire in the attic when installing a horizontal fan coil in the ceiling. If you zoom in you can see it better, I like how this had to happen in the lowest part of the attic..lol
- 4
23 hours ago, KnarlyCarl said:
Just put one in today, totally missed an after photo. Used propress copper and had to do a little funny looking piping because of this goofy manifold setup where the previous water heater had joined up.
Replaced a 120 gallon with a 50 gallon, completely different sizes, so it doesn't exactly pipe in the same
Homeowner rented the previous water heater and said he could have paid for 2 new water heaters with how much he paid in rent for the previous one lol
@Justin Hernandez anybody in your area rent a water heater from the electric company? They used to put them in by the truckloads around here, maybe 15+ years go, we've been slowly replacing them, and what a bear to pull them out, they are all heavy massive 120 gallon tanks....
You know how many times I forget to take pictures, a lot. I just start ripping and tearing and all of a sudden I'm like I should have taken a picture beforehand..lol I only see gas water heaters rented and there old Rudds that finally start to leak form like the 60's slowly but surely I'm replacing them. To bad they have to pay every month or I will say they got there moneys worth and then some. Its funny because you have to call them to pick up the old heater, which makes no sense scrap an't worth it.
On 12/9/2016 at 8:33 PM, JimboS1ice said:
Also looks like some one round house kicked it down the stairs before they installed it
Sent from my iPhone using Tapatalkits used..lol
23 hours ago, KnarlyCarl said:LOL that's terrible, but good one haha
LOL need some cheese with that whine?
I think those water lines could use an extra coupling or two, it might add some more strength to the ones already there hhaah
They sell them in contractor packs for a reason..lol
4 hours ago, Foneguy said:
Love mine, agree about the hinge. Keep it mind the light is a bit yellow, so brightness factor may be off by a lumen or two...
Makes sense
Just now, RickyMcGrath said:
I did pickup a few cell phones from HD this afternoon for 1¢ each. Maybe a truck is next.Yea there just giving away those Samsung phones, there a little hot
6 hours ago, JMG said:
I notice the lack of a drop tube on the pop-off valve too.
Yea I did that too I did mention it on my post
5 hours ago, khariV said:Nice. My water heater was installed with an overflow drain pipe stretched across the floor 4" up from the floor and the romex pulled TIGHT across the attic because they were too cheap to put in an extra 10' of wiring to staple it up properly.
Yea but that's work and work is hard
6 hours ago, comp56 said:
terrible and what is worse is the unsuspected home owner may not know any better to know if it is safe or not. however in some obvious cases you can just see it don't look right.......don't need to know how to play guitar to know someone playing it made a mistake.......
Haha, 2 bright red wire nuts should be easy to see
6 hours ago, RickyMcGrath said:So how does Stevie pick paint colors?
This sucks, I would take the 1 cent store credit and use it to buy a new pick up truck
- 2
A General Contractor installed this, I found it wired just like that. I thought I got an after photo of the electrical redone and relief valve piped in but I guess I forgot. Sucks, if I ever go back I will get a picture. No connector on the greenfield flex on the timer and a metallic greenfield connector on seal tight. Can't forget about the timer just floating in the air and wire nuts just hanging out. They lost the screws to the j-box on the heater so I guess they just said fuck it. I mean you can push the wire in at least but hey whatever.
- 2
On 12/6/2016 at 1:31 PM, olletsocmit said:
The DeWalt police will come out and arrest me if I touched a red tool..lol
15 hours ago, Bigmikez said:
Congrats man trust me your gonna love it dude?
If its yellow I likes
- 2
16 hours ago, JimboS1ice said:
Maybe they'll update their light, if that thing had 30% more output well it would be even better
Sent from my iPad using TapatalkAre you implying theres a new light coming out?? I would love 30% more power!!
21 hours ago, WigWagWorkshop said:
Is it wrong, that the first thing I thought of is it was going to be parked at a strip joint lol.
If he was he has a great alibi, he has a lighting contract with a strip club. Its funny but true..lol
- 2
Ductless - split AC installls?
in Around The House
Like Carl said Mitsubishi is the best and of coarse the most expensive but its worth it. I install minis as well and I wouldn't recommend that you install it yourself if you never worked with air conditioners before. If installed wrong your compressor will live a short life and it will cost a lot of money to replace. But the most dangerous part is the refrigerant part if you get liquid refrigerant on yours hands it will burn you and your hands will be in severe pain for the rest of your life. Plus there is a lot of specialty tools and a lot of small tips you need to know in order to not have a problem down the line.
