The.Handyman
554 -
13
Posts posted by The.Handyman
Where are you located? I have the Metabo 8.0ah batteries. They are available in the US from Ohio Power Tool and Toolbarn.I've contacted a few retailers here and none of them have any idea when the 8.0ah battery packs will be out even though it says they are available on metabo website. I wonder why metabo is now the one playing catch up in terms of amp hours, although, having said that, I have original 4ah metabo batteries at least 6 years old and I could swear they out perform some other 5ah platforms I own, even though they are extremely well used!
Sent from my SM-G960U using Tapatalk
Just switch the giant framer rafter hook with the 15ga rafter hook and your problem is fixed.I’ve had these guns for about 9 months now and while the framer is powerful and has been fault free the rafter hook is an absolute pain to hook onto tool belt, so I’ve gone back to the paslode for any roofing work. The 15 ga da bradder is junk in my opinion. It is only useful for putting 38mm brads into softwood. Any thing longer and it won’t sink them consistently as with use on anything harder. This gun has been back to the supplier twice for long periods but it still has the same issues. I don’t know if mine is faulty or it’s just a poor gun. I regret this purchase as the combo cost around $1300 au and I don’t use either gun often now.
Why wouldn't they? The power station is open top and the 12.0ah is the same size as the 9.0ah FlexVolt battery.
Sent from my SM-G960U using Tapatalk -
From what I remember reading, the Mini/Midi have the same motor as the larger vacs but suction is down a little CFM due to the abrupt 90* fitting going into the vac
Sent from my SM-G960U using Tapatalk- 1
Yes
Sent from my SM-G960U using Tapatalk- 3
Just to clarify. I am not a shill, just being silly. Companies send products for showcasing and review. I have zero obligations to say, hey, this is awesome. I critique everything equally.
Travis
@TOOLSbyDesign
This shill has the little 6 1/2". I cut 4 boards just for you guys. It's awesome.
But seriously, it's fantastic.
Direct from my Milwaukee contact...
We continuously monitor our production operations to ensure we are making tools that meet our standards for the highest quality. We recently identified a small subset of D-Handle Jig Saws that had an out-of-spec accuracy tolerance. Immediately after discovering this, we removed the products. Out of an abundance of caution, we reached out to distribution to return any product that could have possibly been affected so we could best ensure customers get the best product experience, as we intended. Again, this issue was localized to a small subset of product and we’ve returned to shipping normally.
Yup, I discovered that today when I putting together my post.
So crazy.
@TOOLSbyDesign
I love the new compact 21700 cell 3.0ah batteries in the nailers as it offers a wider more stable base to set the nailers on.
Absolutely love and cherish MY Mafell KSS 40. My money is on Makita to be the first to make one.
No adapter coming. Not worth the cost is my bet.
To be honest, most would not use it once you run it off batteries.
If you use a 9.0ah/3.0ah or the 12.0ah/4.0ah in the saw, it will easily rip 2x material. The same is true for the new Milwaukee.
If you will be ripping all day, then battery isn't for you. They definitely have their place and nearly all who have the FlexVolt table saw have nothing but praise for it (outside of the on/off switch).
Available from Acme Tools
$9.99
Shipping August 20th
Sent from my SM-G960U using Tapatalk- 2
Dust port revealed.
Not that I am aware of. Others have made a plug and blank from plastic and screwed it to the existing threaded holes.
Here you go
Here you go
It's excellent. I've covered it quite a bit on my Instagram page.
@TOOLSbyDesign
Batteries getting new stickers, an updated look.That 5amp battery looks weird ?
Well, ergonomics are going to be crap. Should have done the Stanley mount style.
- 2
Yes, as stated in above comments.Does this come with a light?
Smaller deck and not great runtime but still a huge upgrade.New Makita bl mower released in Australia today
Powered by two 18V Li-ion batteries, with the Makita DLM461Z Lawn Mower you get 36V of power and runtime without leaving the 18V platform. The 460mm heavy duty steel deck and 4 swing back blades have been designed to withstand harsh Australian conditions.
Features:
- 18" heavy duty steel deck
- 4 swing back blade system
- High power brushless motor
- 60L catcher with grass level indicator
- Automatic Torque Drive Technology
Specifications:
- Voltage: 36V (18V x 2)
- No load speed: 3300rpm
- Max cutting width: 460mm
- Catcher capacity: 60L
- Cutting height adjustment range: 16mm - 75mm (5 heights)
- Recommended mowing area: 800 - 1600m²
- Length: 1518mm
- Weight: 27.2kg
Specs from Sydney Tools website
26 mins of runtime on 6.0s, from my soures at Makita
Best one out there.I have the Bosch 12v rotory tool and it has been great. Bosch owns Dremel do all of their accessories fit.
You tell us. You have the time to post the question, might as well use that time to just get the answer.After I posted the arbor question it took me 10 minutes to find the answer to that one.
What does a quick Google search say 165 mm equals?
DeWalt 20v 12,000 BTU Portable Radiant Propane Heater
in Dewalt
New DeWalt 20v 12,000 BTU Portable Radiant Propane Heater with LED and USB charging! Just in time for those cool temps. This heater is even indoor safe.
Ready for the jobsite, camping trip, and ice fishing shanty.
Thank you Hugh (@hdcarpentry) for the discovery! He'll be staying warm now.
Model: DXH12B
Price: $189
Available: Now at Northern Tool and select retailers. Soon at Home Depot and other retailers.
Features:
Powered by 20v or FLEXVOLT batteries
3-USB ports for charging personal electronics and accessories
Dual tank capacity provides up to 7 hours of run-time
2 heat settings (6k BTU & 12k BTU) + fan only
Integrated high velocity fan to effectively disperse convective heat
Powerful LED light bar provides ideal working conditions
Factory installed ODS and a thermoelectric safety valve you can feel comfortable using this certified indoor safe heater anywhere.
Product Depth (in.) - 10.5
Product Height (in.) - 14
Product Width (in.) - 15.75
Available now:
https://m.northerntool.com/shop/tools/product_200712330_200712330
