2,563 -
17
Posts posted by Stercorarius
I did hear something about brakes going to be required by osha but that's just hearsay. Milwaukee is a bunch of goofballs who seem to know how to effectively market. They're gambling that people won't switch battery platforms to save $50. That and there was (correct me if I'm wrong) a decent amount of time between the two versions of the grinders being released. When they released the fuel initially they were the only one of the big four with a brushless grinder and DeWalt didn't have one until a couple months ago. So there wasn't a different brand to go to. The price differential just made sense when it was released. Now it doesn't make sense for the non braking to even exist.
I am inclined to agree that it is the most ergonomic design for a cut off tools. Hand held corded 12-14" cut off saws for steel are all shaped like this because that's the best way to hold a tool like this. Even circular saw are in a similar configuration. A back handle and a top handle for the best control. A grinder set up is great for grinding, but even with a cut off wheel on a grinder most of the time it would be more comfortable if it was set up differently. Why not set it up like a grinder? Because it's a cut off tool not a grinder. I've used concrete saws and metal cut off saws and this seems to be the ideal configuration. Metabo does make a 9" cordless grinder in a grinder format. The difference seems to be that the Metabo is geared for upright cutting on guard rails and the likes while this seems more geared for concrete where you are on the ground. To each his own though.
Those look sweet @BMack37
Sowed up a roll for my new wrenches and finally found the only usable part of a Milwaukee tool kit. The fabric. Cost me $3 in needles.
- 3
Yeah like Hilti said only place it would be effective is for the workers using them to not walk off the job site with them in their lunchboxes because they know all the tools only run for one shift. Makita would have to give them or for free if they wanted individuals to use them for theft prevention because 100% of tools would have to be locked before a thief would know not to take them but they would probably still take and/or destroy them just because.
Good to know.
There's no way for a thief to know they're sync locked. I disagree on the "thieves aren't stupid" as well.
And that's on a flat head grinder as well. You can't base the entire line up off of one grinder.
4 minutes ago, dmz2084 said:
Ave found otherwise.
https://www.youtube.com/watch?v=hTqv4mfKYEE&feature=youtu.be&t=2014
Don't really care what that jackass thinks.
Better bearings. Grinds smooth as glass.
I second that. Metabo is the shit.
Local places know me by my first name and are generally a pleasure to deal with. There is just too high of a turnover rate at big box stores to get any kind of service with some exceptions of course, but it will vary between store to store. You get sometimes cheaper prices but at the trade off of having poorer service. At big box stores I can get completely different service just from one day to another.
Gotta say though that KCTool knows how to do things right.
- 2
7 hours ago, Framer joe said:
@Stercorarius..thanks , appreciate it,,we cut 5/8 to an 1 1/4” threaded rod and I think that cutter stops at 5/8” . ..I think....and the band saw will probably come in handy doing something else....I thought about a metal saw but I don’t know how clean the cut is .....
Yeah probably best to go with the band saw then. I have a portable Metabo bandsaw that's a mid size that was a dream for stuff like that when I still had the batteries for it. It was brushed as well so the m12 will probably be perfect.
I believe you are correct. The difference is the old Bluetooth lockout batteries and the new tool connect ones. I used to have a few of the Bluetooth batteries before because they sometimes go on clearance for next to nothing and I doubt they are the same electronics as the tool connect, but I have been wrong before. It might just be a sticker and a name change.
Bosch IDH182 hog ring is worthless.
DeWalt detent pin doesn't require a pick (good or bad depending on who you are, I think it's good)
Metabo battery release button being on the tool is kinda of odd.
Toughsystem radio clock will never work and you get some trippy symbols in the time area. Battery disconnects too easily and doesn't fit large batteries.
Metabo portaband blades are incredibly difficult to get.
Real question is how well does it handle steel. 3 1/2" is enough for probably 80% of the concrete I've cut. That being said if this is a $600 saw I'd be pissed every time I rented a gasser for that 20%. You can get a Makita gas saw for about a grand. The only advantage that they can give this saw is if they make it cheap. I can get a Makita 14" gas one brand new for a grand and would if they offer this as a kit for anything more than $500.
The DeWalt dcs350 is an option, albeit more expensive and only good for threaded rod, if you have to do a ton of it.
Don't like the idea of Hitachi flavored Metabo told. Mostly I just miss my Metabo tools.
17 minutes ago, Bremon said:
It fits the 9.0, so yes. Sounds apparently as good as the toughsystem. Can wait.
Forgot those have 20700 cells as well.
Usually use a sump pump in a 55 gallon barrel of water in the back of my pickup for concrete saws and core drills. If you're going truly cordless I suppose you could use an M18 transfer pump instead. I've never actually seen a corded concrete saw. Just use a gas powered Hilti so I feel like a flex version would be under whelming.
Can it fit the 6.0 non flex batteries?
I really don't think you're going to find pliers up to your standards in the price range you're looking for.
What tools did you buy today?
in Power Tools
That set of wera torx drivers that was on sale. Also a BFDB.
