Stuart Posted December 29, 2017 Report Share Posted December 29, 2017 I've got this air impact wrench which didn't come with instructions nor can I find any online. Is the big red F dot or the little red F dot used to select the torque function? The blue nob, labeled 1-4, is used to select torque strength I'm guessing? I have tried playing around with some different settings on a test nut, but I keep getting a nut that is done up tight! no matter what setting I'm on... Quote Link to comment Share on other sites More sharing options...
Moore,C. Posted December 29, 2017 Report Share Posted December 29, 2017 I've got this air impact wrench which didn't come with instructions nor can I find any online. Is the big red F dot or the little red F dot used to select the torque function? The blue nob, labeled 1-4, is used to select torque strength I'm guessing? I have tried playing around with some different settings on a test nut, but I keep getting a nut that is done up tight! no matter what setting I'm on... Forward-reverse, and I'd imagine the lower coupling would have settings relative to regulator function. Quote Link to comment Share on other sites More sharing options...
