ultra Posted March 9, 2021 Report Share Posted March 9, 2021 i have the power head (PH1400) and use the following attachments: hedge trimmer (HTA2000), string trimmer (STA1500) and edger (EA0800). All three require that I check the grease level via a "sealing screw" and fill it to 3/4 full. well i can hardly see inside the hole and even what little i do see, how do i know if it's 3/4 as opposed to 1/2? all 3 tools have the exact same setup. i tried using a small zip tie to see if i could measure like a dipstick but that was not clear either - as it seems to me that any grease that i put in or that is in will not necessarily settle like a liquid and grease on the sides of the gear box may not show that there is an empty space below.... i spoke to ego support and it was like talking to a person on another planet...they kept putting me on hold and coming back with the same: just look inside and oh btw we have have never had this question before. i did put a little grease in each one but would like a more certain approach. if any of you have done this with these tools i would appreciate your help. if you have not done this with these tools your suggestions are also welcome but please let me know it's a suggestion as opposed to something you have actually done. TIA! Quote Link to comment Share on other sites More sharing options...
Eric - TIA Posted March 10, 2021 Report Share Posted March 10, 2021 Great question. When I get back in town I will look at mine. I never knew I had to grease it. I always thought it was a sealed grease compartment. Thanks for letting me know. When I look at mine, I will see what I can find. 1 Quote Link to comment Share on other sites More sharing options...
GregB Posted September 11, 2021 Report Share Posted September 11, 2021 Can somebody tell me what kind of grease do I need to buy for ego edger Quote Link to comment Share on other sites More sharing options...
Sam F. Posted July 4, 2022 Report Share Posted July 4, 2022 Wild guess but fairly confident this is the answer. Make sure trimmer head is down, that's the position you'd normally have it while in use, so the seal screw is facing to the right. the height of the seal screw is your 3/4 mark. You fill the gearbox up to that point with a syringe while turning the head to spread the grease. Hope this helps! Sam Quote Link to comment Share on other sites More sharing options...
