ANDER11 Posted February 2, 2022 Report Share Posted February 2, 2022 My 18 vts cordess skill saw has started cutting in curves when i am using a straight edge,the blade keeps twisting and jamming. It runs well but even when cutting freehand it starting to jam as well ,any help would be appreciated Regards Ian Quote Link to comment Share on other sites More sharing options...
Altan Posted February 2, 2022 Report Share Posted February 2, 2022 4 hours ago, ANDER11 said: My 18 vts cordess skill saw has started cutting in curves when i am using a straight edge,the blade keeps twisting and jamming. It runs well but even when cutting freehand it starting to jam as well ,any help would be appreciated Regards Ian I also have the same issue, I noticed it happened just after a heavy use. Quote Link to comment Share on other sites More sharing options...
65refinyellow Posted July 11, 2022 Report Share Posted July 11, 2022 Often almost any saw new with a new blade cuts it’s straightest the first few times. I found circular saws are notoriously wanderers. Many people prefer table saws, track saws, and sliding miter saws for sheer straightness. I have found that physically heavy saws like the Skil 77/78/Sawsquatch or dual battery 36v Makita rear handled saws cut the straightest. There is too much mass in the tool so it won’t bounce around as much as lighter weight saws. The heavier weight of many rear handled saws promote fatigue and they’re not fun to use long term. I like my moderately heavy Flexvolt sidewinder saw and it has enough mass to not be thrown off a line but doesn’t feel like a mini tank like the two 36 volt Makita rear handled monsters. Quote Link to comment Share on other sites More sharing options...
