DC618 lack of power
JD
    Thank you for your response.  The depth gauge is fine if you put 2 1/2 nails in the gun it will only set the nail less then 3/4 inch in and then I have to release the nose of the gun.  If I fire the gun with no nails in slide you can see the drive pin mark on the wood. If I use 1 1/4 nail one out of maybe five nails will sink.
                    Thank you
                      J.D.
                     Thank you
                      J.D.
Sound like it needs to be serviced there is a steel profile in the nailer that will wear out over time and needs to be replaced.
  • 2 years later...
    Jonas
    Jonas
