gcarlson Posted December 26, 2013 Report Share Posted December 26, 2013 I have a pd sander that when you first set it on the wood, it takes off in a random direction. You have to apply pressure to get it under control. i need some advice on how to correct the problem as it did not do this when it was new. I've checked the 4 plastic extensions, none broken. I'm wondering if the bearing is bad or if the sanding pad needs to be replaced. They both look fine now. Thanks for your help. Quote Link to comment Share on other sites More sharing options...
