Mudbone Posted April 29, 2014 Report Share Posted April 29, 2014 Just got a new DWE315 Oscillating Tool. When there is no blade in the clamp the two flanges meet and you cannot see the teeth that engage the slots in a blade. With a blade in the clamp the two flanges do not come all the way together and you can actually see the teeth on one side (below) of the blade. Is this how it is supposed to work or should the flanges come together so that you don't see the teeth? TIA Quote Link to comment Share on other sites More sharing options...
Mr. Yellow Posted April 29, 2014 Report Share Posted April 29, 2014 Yes, that is how it works. The teeth don't slot fully into the blade, because they are tapered to prevent any play between the teeth and blade.Also, it does vary a bit from blade to blade how much of the teeth you will see. Nothing to worry about. Quote Link to comment Share on other sites More sharing options...
Gatorb888 Posted April 29, 2014 Report Share Posted April 29, 2014 I see the same thing on mine, should be good to go. Quote Link to comment Share on other sites More sharing options...
